overwriteOutput not working in 10.2.2
6995
6
08-19-2014 03:25 PM
AmyKlug
Ever since upgrading to 10.2.2 my python code(s) tell me the file already exists and won't overwrite (using CopyFeatures or Copy). In ArcCatalog, I have my geoprocessing options set to overwrite and arcpy.env.overwriteOutput = True in my code.
Anyone know of a solution???
Thanks
EDIT: I am copying one feature class to another to a file geodatabase -> feature dataset. Both feature classes and feature datasets have the same projection. Worked fine in 10.1
EDIT2: It won't overwrite using modelbuilder either. Get "Already exists" error
AmyKlug
After some testing I think with 10.2.2 the feature dataset and the feature class can't have the same name; If they do/you want them to, you have to first delete the feature class then copy in the updated version.
BruceHarold
Esri Frequent Contributor
I can’t reproduce – a rerun of a tool works:
>>> arcpy.Copy_management(in_data="C:/Temp/DougGolfCourses.gdb/GolfCourses",out_data="C:/Temp/DougGolfCourses.gdb/GolfCourses_Copy",data_type="FeatureClass")
<Result 'C:
Temp
DougGolfCourses.gdb
GolfCourses_Copy'>
True
>>> arcpy.GetInstallInfo()['Version']
u'10.2.2'
AmyKlug
I tried copying a feature class from GDB to GDB and FDS to GDB it worked fine. GDB or FDS to FDS would not overwrite. There seems to be an issue with overwriting a feature class in a feature dataset (FDS).
XanderBakker
Esri Esteemed Contributor
When I try the code below which copies the source to dest1 and dest2 (featureclass in a feature dataset), it works without any problem in 10.2.2.
import arcpy
source = r"C:\Forum\overwrite\source.gdb\myFC"
dest1 = r"C:\Forum\overwrite\dest1.gdb\myFC"
dest2 = r"C:\Forum\overwrite\dest2.gdb\featDS\myFC"
arcpy.Copy_management(in_data=source,out_data=dest1,data_type="FeatureClass")
arcpy.Copy_management(in_data=source,out_data=dest2,data_type="FeatureClass")
The only way I could reproduce this error was trying to write to the dest2 featureclass without using the feature dataset in the path. Like this:
dest2 = r"C:\Forum\overwrite\dest2.gdb\myFC"
Are you sure you are using the output feature dataset in referencing the output featureclass?
Kind regards, Xander
AmyKlug
curtvprice
Good advice, Amy!
In my experience naming any two objects within in the geodatabase or folder the same can break tools (or your own model or script tool). Layer names and dataset names get duplicated in your memory namespace and bad karma grows...
Like starting names with a number or using spaces in your path, things may work okay at first, but break at the least opportune moment for you.  My advice: learn from the suffering from others and don't tempt fate.
This includes:
  • Feature classes within parallel feature datasets
fc1/features
fc2/features
  • Objects in a folder workspace (with different extensions)
mydata.shp
mydata.tif
mydata (folder)
mydata (Esri grid)
To avoid issues,  everything in a workspace should have a unique name.
GerryGabrisch
I had the same problem using 10.1 going from tables in a gdb to feature dataset feature classes.  Changing the output to something other than the name of the input table solved my two days of head scratching.  Thanks!
