Odd results from getCount
1160
06-19-2014 11:23 AM
AliciaMein
I was QAQC'g my code results and found unexpected values.
My code queries point and polygon layers looking for how many negative test result are gathered before a positive.
for grid in grids:
        dates = []
        arcpy.SelectLayerByLocation_management("cwdpts4Anlys", "WITHIN", grid.shape, "", "NEW_SELECTION")
        positives = arcpy.SearchCursor("cwdpts4Anlys",' "PRION_DETECTED" = 1 ' , "", "SAMPLEDATE" )
        for positive in positives:
            dates.append(positive.SAMPLEDATE)
        earliest = min(dates)
        grid.setValue("FrstPosDte", earliest)
        posYear = earliest.year
        print posYear
        negDates = []
        arcpy.SelectLayerByLocation_management("cwdpts4Anlys", "WITHIN", grid.shape,"", "NEW_SELECTION")
        negatives = arcpy.SearchCursor("cwdpts4Anlys",' "PRION_DETECTED" = 0 ', "", "SAMPLEDATE")
        for negative in negatives:
            negDates.append(negative.SAMPLEDATE)
        if negDates:
                earliestNeg = min(negDates)
                print earliestNeg
                grid.setValue("FrstNegDte", earliestNeg)
                where = "EXTRACT(YEAR from {0}) <= {1}".format(arcpy.AddFieldDelimiters("cwdpts4Anlys", "SAMPLEDATE"), posYear)
                arcpy.SelectLayerByAttribute_management("cwdpts4Anlys", "SUBSET_SELECTION", where)
                result = int(arcpy.GetCount_management("cwdpts4Anlys").getOutput(0))
                print result
                grid.setValue("NgPriorPs", result)
        else:
                grid.setValue("NgPriorPs", 0)
        grids.updateRow(grid)
It appears when checking the values for negatives prior to positive that the getCount includes the earliest positive (or it is always one more than expected.
Why?  Do I need to physically clear the selection before making the second "New_Selection"
Alicia
