NumPyArrayToTable returning RuntimeError: create table
1348
04-04-2022 08:07 AM
MollyMoore
One of my scripts uses arcpy.da.NumPyArrayToTable. I ran this script about 2 years ago without incident. Now, it is throwing the error:
This is the output of the print statement of my array that I'm trying to copy over to a table:
array([('S1', 'G5', 3778,  14702, 'PDSAL02240', 'Salix pedicellaris', 'Bog Willow', None, None, 'Y', None, 'N', 'PE', None, None, None, None, 'N', 'EXCLUDE from ER per DCNR 2019-01-02 (P19BOW01).', None, None, None, None, None, '28-Feb-22', 'G5', 'S1', 'in biotics', 'G5', 'S1', 0.6, 0.008, 0.33333333),
       ('S1', 'G3G5', 7384, 478722, 'NBMUS1A1B0', 'Ptychostomum cernuum', None, None, None, 'Y', None, None, None, None, None, None, None, 'N', None, None, None, None, None, None, '28-Feb-22', 'G4', 'S1', None, 'G4', 'S1', 0.7, 0.   ,        nan),
       ('SX', 'G4G5', 4113,  15067, 'PMCYP036C0', 'Carex hyalinolepis', 'Shore-line Sedge', None, None, 'Y', None, 'PX', 'PX', None, None, None, None, 'N', None, None, None, None, None, None, '28-Feb-22', 'G4', 'SX', 'in biotics', 'G4', 'SX', 0. , 0.   ,        nan),
      dtype=(numpy.record, [('SRANK', '<U4'), ('GRANK', '<U9'), ('OBJECTID', '<i4'), ('ELSUBID', '<i4'), ('ELCODE', '<U10'), ('SNAME', '<U46'), ('SCOMNAME', 'O'), ('SRANK_CHGD', 'O'), ('SRANK_RVWD', 'O'), ('EO_TRACK', 'O'), ('USESA', 'O'), ('SPROT', 'O'), ('PBSSTATUS', 'O'), ('PBSDATE', 'O'), ('PBSQUAL', 'O'), ('SGCN', 'O'), ('SGCN_COM', 'O'), ('SENSITV_SP', '<U1'), ('ER_RULE', 'O'), ('MOD_BY', 'O'), ('MOD_DATE', 'O'), ('CHG_TYPE', 'O'), ('CHG_INFO', 'O'), ('CHG_SRC', 'O'), ('EXPT_DATE', '<U9'), ('Rounded_GRANK', 'O'), ('Rounded_SRANK', '<U3'), ('temp_taxostatus', 'O'), ('GRANK_rounded', '<U3'), ('SRANK_rounded', '<U3'), ('rank_score', '<f8'), ('resp_score', '<f8'), ('rarity_score', '<f8')]))
Just checking to see if anyone can see any issues in the array that might be throwing this error or if anyone has any other ideas about what I can try to do to fix the issue. Thanks!
Tags (3)
ABishop
Hello Molly,
I am no expert in arrays, but I found this thread that may offer some help for your issue.
https://community.esri.com/t5/python-questions/arcpy-da-numpyarraytotable-returns-quot/m-p/756281#M5...
Amanda Bishop, GISP
DanPatterson
MVP Esteemed Contributor
format issues.  and really long lines but, here you go.
dt = [('SRANK', '<U4'), ('GRANK', '<U9'), ('OBJECTID', '<i4'),
z = np.array([
         None, 'G4', 'S1', 0.7, 0.,  np.nan),
         'G4', 'SX', 'in biotics', 'G4', 'SX', 0., 0., np.nan)],
        dtype=dt)
# --- an example
z['resp_score']
array([  0.01,   0.00,   0.00])
... sort of retired...
