NumPyArrayToRaster with string array
1145
04-03-2012 01:57 AM
RA1
I am trying to use the NumPyArrayToRaster for a string array
I am using two input arrays: arcpy.RasterToNumPyArray(raster1) and arcpy.RasterToNumPyArray(raster2)
with dtype('uint8')
My output array is created from a loop that sums both input arrays in str format, something like: str(array1)+"+"+str(array2) with dtype='|S4'
When I try to export it to raster format I get the following error:
raceback (most recent call last):
  File "<pyshell#103>", line 1, in <module>
    arcpy.NumPyArrayToRaster(outputarray)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\__init__.py", line 1165, in NumPyArrayToRaster
    return _NumPyArrayToRaster(*args, **kwargs)
ValueError: Argument in_array: Array type is not supported.
Is there any limitation of type of arrays we can export to raster format ??
PhilMorefield
You're probably better off working the arrays as array objects instead of strings, especially if you're eventually going to convert them to a raster. I've never seen a raster with text for values.
