New at Python scripting (Definition query and Looping)
1255
03-31-2011 05:08 AM
AdamTomko1
I am trying to create a script that Loops through a layer and creates multiple defintion queries on that layer. The layer is building lines and i want to create multiple definition queries so that each floor can be queried out and then mapped. I am having trouble getting started. I tried creating a script that simply creates a definition query for a layer in a mxd. It says the script is executing but when i open up the project nothing changes. Any help  would be appreciated. Some of my scrip is below.
import arcpy, os
mxd = arcpy.mapping.MapDocument("M:/nih/AsbestosAbatement/Floorplans/BLDG_6A/Floorplanpdf.mxd")
for lyr in arcpy.mapping.ListLayers(mxd):
    if lyr.name == "BuildingFloorLInes":
        layer.definitionQuery =[FLR] = '02'
        layer.update
print 2
JasonScheirer
Esri Alum
You need to save the MXD when you're done.
import arcpy, os
for lyr in arcpy.mapping.ListLayers(mxd, "BuildingFloorLines"):
    layer.definitionQuery = "[FLR] = '02'"
mxd.save()
print 2
If you're currently in arcmap and want to act on the active map:
import arcpy, os
mxd = arcpy.mapping.MapDocument("current")
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
print 2
StevenArebalo
layer.definitionQuery='[FLR]="02"'
Your query isn't held together with outer quotes. Don't know how layer.definitionQuery reacts to ambiguous assignments, but it may be set to "" and would explain returning all records.
*beat to the punch*
