New and need some major help!!!!!
1741
01-31-2013 06:59 AM
AndrewSmith
I have a field (string 150), called RFID. It has a text coded number for RFID tags. I need to chop off the first part of the number, and leave only 8 identifying number at the back. is there a way of doing this, since I have over 2000 RFID tags, and I do not want to do it by hand.
Example
1st Field RFID_Tag (String, 150) 3000000000000000000000000000000000000000BC201001078 (needs to be reduced into field)
2nd field RFID_Code(String, 50)  BC201001078
They are both in the same table. The RFID_Tag comes from a spread sheet imported into ArcMap, them made into a feature class table, then a Feature class. But how do I remove the excess front numbers
Thank you for all your ideas and help.
Andrew
MathewCoyle
Honored Contributor
You could just do this in field calculator unless you want to make it a script. Your example has more than 8 characters so modify the number you want if it isn't 8.
RFID_Code =
!RFID_Tag![-8:]
AndrewSmith
Thanks, that worked great, Thanks for the help. I also just learned where the results get posted to as well.
Thanks Mathew
MathewCoyle
Honored Contributor
Thanks, I just tried that, and keep getting there was a failure durring proessing, check Geoprocessinf Results widow for details.
No detail window is to be found either.
Did you use the Python parser?
