needing some help with python code lyr not defined
4082
10
04-30-2019 12:57 PM
by Anonymous User
Not applicable
i am having some issues  running  a simple  python script   alongside my data  driven pages map. I am trying to  clip out  some roads and selected  names from the outside of my layer scope i have written the code down below could anyone help me with this    the   lines in question  is  highlighted in bold.    still new to python  if someone can help  that would be great. thanks
import arcpy
# Set overwrite option
mxd = arcpy.mapping.MapDocument(r"W:\Information Technology\GIS\Projects\Wildlife\BigGame\PermitMaps\BigGameUnitsDDP_ElkLandscape.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
for lyr in arcpy.mapping.ListLayers(mxd, "City*", df):
    if lyr.name == "City Points (2010)":
        city_lyr = lyr
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
    mxd.dataDrivenPages.currentPageID = pageNum
    pageRow = mxd.dataDrivenPages.pageRow
    pageName = mxd.dataDrivenPages.pageNameField.name
    DDP_PageName = pageRow.getValue(pageName)
    for lyr in arcpy.mapping.ListLayers(mxd, "Elk*", df):
        if lyr.name == "ElkUnitsSDE - match":
            unit_lyr = lyr
            arcpy.SelectLayerByAttribute_management(unit_lyr, 'NEW_SELECTION', '1=1')
        if lyr.name == "ElkUnitsBoundaryRds":
             unit_boundary_lyr = lyr
             unit_boundary_lyr.definitionQuery = "Units Like " + "'%" + DDP_PageName + "%'"
    print city_lyr.name
    print unit_lyr.name
    arcpy.SelectLayerByLocation_management(city_lyr, 'INTERSECT', unit_lyr, '1 Mile', 'NEW_SELECTION', 'NOT_INVERT')
    selcount = int(arcpy.GetCount_management(city_lyr)[0])
    print selcount
    if selcount == 0:
        print ('No city points selected')
    else:
        arcpy.CopyFeatures_management(city_lyr, r"W:\Information Technology\GIS\Projects\Wildlife\BigGame\PermitMaps\Python\BigGameUnits.gdb\Cities_Sel")
        city_lyr.replaceDataSource(r'W:\Information Technology\GIS\Projects\Wildlife\BigGame\PermitMaps\Python\BigGameUnits.gdb', 'FILEGDB_WORKSPACE', 'Cities_Sel')
    for lyr in arcpy.mapping.ListLayers(mxd, '*', df):
        arcpy.SelectLayerByAttribute_management(lyr, "CLEAR_SELECTION")
    print "Exporting page {0} of {1}".format(str(mxd.dataDrivenPages.currentPageID), str(mxd.dataDrivenPages.pageCount))
    arcpy.mapping.ExportToPDF(mxd, r"W:\Information Technology\GIS\Projects\Wildlife\BigGame\PermitMaps\2019 Permit Maps\Elk" + "_" + str(DDP_PageName) + ".pdf", resolution=150, georef_info="false", jpeg_compression_quality=75, image_quality="NORMAL")
    city_lyr.replaceDataSource(r'Database Connections\GIS_WEB.sde', 'SDE_WORKSPACE', 'GIS_WEB.SDE.CityPoints')
del mxd, df, city_lyr, unit_lyr, unit_boundary_lyr
Tags (1)
LukeWebb
when it says "City_Lyr is not defined", what this means is, you have not yet "defined" your city layer
This is because in this line of code:
        city_lyr = lyr
it never actually gets to run the line of code:
 city_lyr = lyr
Which is where you try to define it. The reason for that, I am not so sure, but the "If" statement is somehow not letting any of your layers get defined as the city lyr.
Same issue regarding your other layer.
