need help with UpdateCursor and .updateRow(row)!!!
2726
05-21-2013 07:35 AM
AndrewWickham
Hi all,
I am studying python scripting for geoprocessing and am having trouble with a update cursor loop.
"Property_Layer" is a feature layer and I want to narrow the arcpy.UpdateCursor to empty "LOCALITY" fields. I then want to use the for loop to set the "LOCALITY" field to the variable "value".
my code stalls at the rows.updatRow(row) line. I'm not sure I can use a feature layer with the UpdateCursor....!?
I am new to this so any help would be greatly appreciated!
    rows = arcpy.UpdateCursor ("Property_Layer",'"LOCALITY" = ' + "'" + "'")
    row = rows.next()
        for row in rows:
            row.setValue ("LOCALITY", value)
            rows.updateRow(row)
            del row, rows   #delete cursors
AndrewWickham
P.S the indenting on my code is correct, not like what is shown in my first post.
thanks!
Andrew
ChrisSnyder
Honored Contributor
I think it would look more like this:
value = "CAT"
rows = arcpy.UpdateCursor ("Property_Layer","LOCALITY = '' OR LOCALITY IS NULL") #blank string or Nulls
for row in rows:
   row.setValue("LOCALITY", value) #assuming this is a text field
   rows.updateRow(row)
del row, rows
ThaiTruong
Here is the correct syntax to create an update cursor to help you started
import arcpy
def UpdateField(value):
    # Create update cursor for your feature class
    # Update the correct path to your feature layer
    rows = arcpy.UpdateCursor(r"C:\Temp\test.gdb\Property_Layer")
    # Update/calculate field to the variable "value"
    for row in rows:
        # Update "LOCALITY" Field
        row.LOCALITY= value
        rows.updateRow(row)
    # Delete cursor and row objects to remove locks on the data
    del row
    del rows
Then you can call this UpdateField() function and pass a variable with a value that you want to calculate the field to.
T__WayneWhitley
Honored Contributor
I think Chris meant to indent the line for updateRow...
ChrisSnyder
Honored Contributor
Woops - yes - correcting that now.
