Need help with simple translation (VBA -> Pyhton)
1314
07-16-2012 12:44 PM
JordanWalker
I need help from someone to translate a small piece of code from VBA to Phython, due to the fact that the company I am working for has upgraded from ArcGIS 9.3.1 to 10.0 and VBA is no longer supported.  The code block is as follows:
static x0 as double, y0 as double
dim pPoint as IPoint
set pPoint = [Shape]
x = pPoint.X
y = pPoint.Y
d = sqr((x-x0)^2 + (y-y0)^2)
x0 = x
y0= y
This is used with the calculate field tool inside model builder and as far as I can tell retrieves info about two points and calculates the difference in distance between them. I have attempted a few translations on my own with little success using !shape.firstpoint.x!, !shape.firstpoint.y!
Unfortunately my knowledge is lacking and I need some assistance.  If you are able to help, that would be greatly appreciated!
Jordan
MathewCoyle
Honored Contributor
Are they multipart features? You may need to strip out each part first to access the X,Y geometry. If you are translating anyways, I would suggest using cursors instead of field calculator.
Also, VBA is supported in 10.0 still, you just need to authorize the VBA license. It's a good idea to start switching though, since 10.1 will be the last version you can even use VBA from what I understand; after which it will be fully deprecated.
JordanWalker
They are point files with thousands of GPS fixes from cattle collars.  However, I think I may be onto something with the following:
def calc_distance(shape, x0, y0):
    point = shape.getPart(0)
    X = point.X
    Y = point.Y
    d = math.sqrt(pow(X-x0,2) + pow(Y-y0,2))
    return d
Expression:
calc_distance(!SHAPE!, 0, 0)
I will try it out today.
