Need help with Replace in Field Calculator
5232
07-30-2012 01:43 AM
NumaGremling
Hi everyone,
I am trying to set up a probably very easy expression, but it looks like I???m missing something. Even though I have python background I am new to using it in the Field Calculator (this is actually my first time trying it).
OK, so in order to be able to correctly join a table to a shapefile I had to modify river names. I ended up adding an underscore + a number to specific river segments. The attached screenshot shows what I mean.
[ATTACH=CONFIG]16464[/ATTACH]
Now, after successfully joining my table I would like to get rid of that extension.
I assume that the replace method is the correct one and according to Desktop Help the syntax should be as follows:
!STATE_NAME!.replace("california", "California")
Now, nothing is happening when running my syntax:
!Gewässerna!.replace("_%", "")
Am I not allowed to use a wildcard? Or am I not allowed to replace a string with nothing? Or am I not allowed to replace parts of a string in the first place?
Again, I???m fairly new to using coding in the Field Calculator. I appreciate your help!
JakeSkinner
Esri Esteemed Contributor
Hi Numa,
I'm not sure if you can use a wildcard with the replace method.  The method will read everything within quotes as a string.  Try the following instead:
Pre-Logic Script Code:
def replace(field):   if "_" in field:     return field.split("_")[0]   else:     return field
Under the code block:
replace(<fieldname>)
Note:  Be sure 'Python' is checked at the top of the Field Calculator
JakeSkinner
Hi Numa,
NumaGremling
This worked perfectly fine! Thank you so much!
I keep looking at the syntax and I just want to make sure I entirely understand what is going on.
Line 3 is where I am not entirely sure. Here is how interpret it;. Please correct me if I am wrong:
- We are looking for �??_�?�
- the index [0] is referring to the character itself
- split will cut off everything from 0 to infinity
If that is true, then that means that split only retains what is to the left of the �??split character�??, right? I remember using split in class and I think we used it to chop up a string to use all of its individual parts (i.e. it did something completely different).
Thanks for the clarification!
JakeSkinner
Yes, you are correct.  The split method will return a list of values.  For example:
string = 'Saur_5'
string.split("_")
will return:
['Saur', '5']
Specifying an index will return the value in the list.  Ex:
string.split("_")[0]
will return:
'Saur'
