Need Help with Python Expression to Calculate Field
1389
03-18-2021 10:33 AM
KyleSmiley_nrcs
I am trying to calculate a field using another field. The code expression is valid and it executes the code but it does not provide the values i'm looking for. Instead, it shows 0's. But I want it to show values of .2 and .33, respectively for the Assigned Percent Loss field that I am trying to calculate.. Any help is greatly appreciated.
JayantaPoddar
MVP Alum
Looks like "Assign_Per_Loss" is LONG or SHORT datatype. It should be FLOAT or DOUBLE.
Think Location
by Anonymous User
Not applicable
What is the field's data type?  It is probably rounding and it should be set to float and the format set to show the correct number format.
BlakeTerhune
MVP Frequent Contributor
JayantaPoddar
MVP Alum
Think Location
KyleSmiley_nrcs
Code worked and provided the correct output after changing it from long to float. Thanks everybody!
