Need help using Python in a Calculate Field operation
1947
09-08-2012 06:30 AM
GlennKammerer
Windows XP Pro SP3
ArcView 10.0 SP2
I have a pretty simple task that would be well suited for the attribute table's Calculate Field functionality, but I don't even know where to start as far as doing this with Python. I've written dozens of Python standalone scripts, so I don't think it's a language issue. I just don't know how to do this in the Calculate Field window.
I have five fields involved in this calculate.
Fields A1, A2, B1 and B2 are Long Integer fields. This is the logic:
if (A1 == B1 and A2 == B2):
  return "A AND B IDENTICAL"
else:
  return "OK"
I would like the returned value to appear in field C.
Now how in the heck would this be done in the Calculate Field window?
ALSO...is there a trove of Python code block examples somewhere?
FabianBlau
Read the help, there are many examples and tips:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Calculate_Field_examples/00170000004s0...
In the Field Calculator check "Show Codeblock" and insert the code:
if ([A1] == [B1] and [A2] == [B2]):
    output = "A AND B IDENTICAL"
else:
    output = "OK"
For "<fieldname> = " insert:
output
KimOllivier
Honored Contributor
If you are going to use Python to calculate fields with lots of logic then it is much easier to use an UpdateCursor. The FieldCalculator wraps a cursor around your expression anyway so it is the same thing. I regard the FieldCalculator as a prop to use in ModelBuilder only.
The benefits of using a cursor are many:
  • The logic is easier to write and understand
  • It is easier to test the result and debug
  • You can handle exceptions and unexpected input
  • The syntax is simpler
  • If you are using a join, then use a python dictionary instead for speed.
with arcpy.da.UpdateCursor(feature_class,['A1',' B1',' A2', 'B2',' C']) as cur:
      for row in cur:
         if (row[0] == row[1] and row[2] == row[3]):
              row[4] = "A AND B IDENTICAL"
         else:
             row[4] = "OK"
         cur.updateRow(row)
