Need Help Changing Paths to SDE
3794
10
04-08-2011 08:45 AM
JeffPickles
This script works great when dealing with SHPs and GDBs, but crashes Python when I try to run it for SDE data. What am I doing incorrectly?
import arcpy, os
## Input folder containing MXDs you want to change here.
## This should be the root folder.
start = "X:\ArcGIS"
## The os.walk command tells the script to go through
## all subdirectories in the 'start' folder.
for root, dirs, files in os.walk(start):
    for file in files:
        ## This command looks for MXD files and ignores all others.
        if file.endswith(".mxd"):
            path = os.path.abspath(os.path.join(root, file))
            mxd = arcpy.mapping.MapDocument(path)
            ## The string you want to find, the new string you want to replace it with.
            mxd.findAndReplaceWorkspacePaths(r"X:\ArcGIS\OLD.gdb\Old_Units", r"Database Connections\server.sde\SDE.DBO.New_Units")
            mxd.save()
del mxd
Everything works fine until I put the SDE connection in.
FrankVignati
change this:
to this:
mxd.findAndReplaceWorkspacePaths(r"X:\ArcGIS\OLD.gdb\Old_Units", r"Database Connections\server.sde", False)
JakeSkinner
Esri Esteemed Contributor
Try using the replaceWorkspaces function:
import os, arcpy
folder = r"C:\TEMP"
for (path, dirs, files) in os.walk(folder):
    for file in files:
                mxd_path = os.path.join(path, file)
                mapdoc = arcpy.mapping.MapDocument(mxd_path)
                mapdoc.replaceWorkspaces(r"C:\DATA\Philadelphia.gdb", "FILEGDB_WORKSPACE",
                                         r"Database Connections\SQL - VECTOR@VECTOR.sde", "SDE_WORKSPACE")
                mapdoc.save()
del mxd_path
del mapdoc
JeffPickles
Jake,
Will this work even though I have a new feature name?
EDIT: Tried this both with feature names and without. Unknown error on each.
  File "X:\Python_Code\SubDir_Search_and_Replace_w_SDE.py", line 11, in <module>
    r"Database Connections\server.sde\SDE.DBO.New_Units", "SDE_WORKSPACE")
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\utils.py", line 181, in fn_
    return fn(*args, **kw)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\_mapping.py", line 754, in replaceWorkspaces
    return convertArcObjectToPythonObject(self._arc_object.replaceWorkspaces(*gp_fixargs((old_workspace_path, old_workspace_type, new_workspace_path, new_workspace_type, validate), True)))
ValueError: MapDocObject: Unexpected error
JakeSkinner
I think there may be a bug with the mapping.findAndReplaceWorkspacePaths function.  I've been running some tests with ArcGIS 10 SP1 and cannot seem to get this to work.  For example, I tried a simple test and the paths would not update:
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\Temp\Fires.mxd")
mxd.findAndReplaceWorkspacePaths(r"C:\TEMP\test.gdb", r"C:\Temp\Python_Test.gdb")
mxd.saveACopy(r"C:\Temp\Project2.mxd")
del mxd
I would recommend escalating this matter to tech support.
MathewCoyle
Honored Contributor
This works for me, ArcGIS 10 SP1
import arcpy
arcpy.OverWriteOutput = 1
mxd_path = "C:\\GIS\\IHTP\\testing.mxd"
old_db = "C:\\GIS\\Working\\Python\\Test\\IHTP_FGDB.gdb"
new_db = "C:\\GIS\\ihtp\\IHTP_FGDB.gdb"
mxd = arcpy.mapping.MapDocument(mxd_path)
mxd.findAndReplaceWorkspacePaths(old_db, new_db, True)
mxd.saveACopy("C:\\GIS\\IHTP\\testingTrue.mxd")
del mxd
In regards to the SDE connection, this should work if you are renaming one layer, if there are multiple layers to rename then that would complicate things.
import arcpy
print "Starting"
old_lyr = "C:\\GIS\\Working\\Python\\Test\\IHTP_FGDB.gdb\\ihtp"
new_lyr = "IHTP_OLD_AUG09"
new_db = ("C:\Users\\coylema\\AppData\\Roaming\\ESRI\\Desktop10.0\\ArcCatalog\\Connection to winms-wooddb.sde")
#new_db = "C:\\GIS\\ihtp\\IHTP_FGDB.gdb"
lyrs = arcpy.mapping.ListLayers(mxd)
for i in lyrs:
    if i.supports("DATASOURCE") and i.supports("DATASETNAME") and i.dataSource == old_lyr:
        i.replaceDataSource(new_db, "SDE_WORKSPACE", new_lyr, False)
mxd.saveACopy("C:\\GIS\\IHTP\\testingSDE.mxd")
del mxd
del lyrs
print "Done"
Edit: When changing data sources, I use the SDE file on disk, not the instance from ArcGIS. This is because if another user added the layer to the mxd, or you added it with a previous version of ArcGIS, I have found these links are not always updated in the background dataSource property, even though they connect fine in ArcGIS. Not sure why this is, or if it is just me.
JeffPickles
Success! Thanks, Mathew.
I ended up plugging your code into the os.walk command from my previously failed code so it would go through recursive directories. The only issue now is I need to find out how to put a progress bar into the code so I don't just stare at "Starting..." for the length of the process. 😉
Final code:
import arcpy, os
print "Starting"
start = r"X:\ArcGIS"
old_db = r"X:\ArcGIS\Old\Old_GDB.gdb"
old_lyr = r"X:\ArcGIS\Old\Old_GDB.gdb\Old_Units"
new_lyr = "SDE.DBO.New_Units"
new_db = ("Database Connections\server.sde")
    for file in files:
            for i in lyrs:
            mxd.save()
del mxd
del lyrs
print "Done"
MathewCoyle
Honored Contributor
In terms of tracking your script, I like putting print functions in loops (as long as they aren't too large) to tell me what it is doing.
Something simple under your if statement, such as
    print file
If you want to get real creative, you can get a count of all your mxds first with a similar loop. Keep a count of the number of mxds converted after the datasource as been successfully changed, divide that value by the total count of mxds, round it to the nearest integer, and print every X value, eg 10 percent, 20 percent etc
There is probably an easier way to do that, I've never had occasion to do something of that sort.
TerrySilveus
Final code:
import arcpy, os
print "Starting"
    for file in files:
            for i in lyrs:
            mxd.save()
del mxd
del lyrs
print "Done"
google -> progress bar python you'll get a lot of hits
JeffPickles
Yeah, I just went with a quick and dirty
print path
after the save step. Works wells enough for me.
