Copy Features Snag
1176
04-12-2011 07:26 AM
DuncanRager
Greetings,
I'm writing a basic snap to line script that goes something like this...
## Snap to Line
# import modules
import arcpy, os, sys
from arcpy import env
# grab user inputs
env.workspace = arcpy.GetParameterAsText(0)
snapLine = arcpy.GetParameterAsText(1)
snapType = arcpy.GetParameterAsText(2)
snapDistance = arcpy.GetParameterAsText(3)
fcBackupDir = arcpy.GetParameterAsText(4)
# define variables
fcList = arcpy.ListFeatureClasses()
# make backup copies of features
for fc in fcList:
 fcBackupName = fcBackupDir + fc
 arcpy.CopyFeatures_management(fc, fcBackupName)
# set snapping environment
snapEnv1 = [snapLine, snapeType, snapDistance]
# snap to line
for fc in fcList:
 arcpy.Snap_edit(fc, [snapEnv1])
...and I keep getting an error saying...
Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000210: Cannot create output C:\GIS\Base\NHD\SGBD\Raw_Shapefiles\Bank_P.shp Failed to execute (CopyFeatures).
Does this have to do with a schema lock? Is my directory syntax off?
Thanks so much,
DR
MathewCoyle
Honored Contributor
Did you try these steps?
http://help.arcgis.com/EN/ARCGISDESKTOP/10.0/HELP/index.html#//00vp0000000n000210.htm
Does the file name already exist?
DuncanRager
I did see that article. The backup workspace is different, and I tried different names and all came up with the same error.
DuncanRager
Fixed it. Turned out to be a syntax error in my snapping environment... I used "snapeType" instead of "snapType".
I guess that's why you're supposed to use Try Except statements.
