MySql: Loop through list of tables and return number of rows
11422
10
10-21-2021 12:44 PM
JoeBorgione
Back in 2020 I was messing around with python and mySql. (see this post) and today I'm back to it.
I can get a list of tables in my database like this:
import mysql.connector as mysql
cn = mysql.connect(user = 'myUserName', password = 'myPassword', host = 'myHost', database = 'master_db')
cursor = cn.cursor()
cursor.execute("Show tables;")
myresult = cursor.fetchall()
myresult is a list of tuples that looks a little like this:
[('accessmoderules',),
 ('accessmodes',),
 ('activitylogs',),
What I want to do is loop through myresult and return the table name and the number of records right next to it, but can't quite seem to get it right.  If I try this:
for table in myresult:
    query = f""" SELECT * FROM from master_db.{table[0]};"""
    number_of_rows = cursor.execute(query)
I get this error:
ProgrammingError: You have an error in your SQL syntax;
check the manual that corresponds to your MySQL server
version for the right syntax to use near 'from master_db.accessmoderules'
at line 1
I can run that very query in a MySql Workbench window and get what I want:
What am I missing on the python side of things?
@RandyBurton
That should just about do it....
Tags (1)
DanPatterson
MVP Esteemed Contributor
FROM from
is this sql?
... sort of retired...
JoeBorgione
mySql
Took care of the double From and get a different error...
File "C:\Clones\Pro282\lib\site-packages\mysql\connector\connection.py", line 1169, in handle_unread_result
raise errors.InternalError("Unread result found")
InternalError: Unread result found
BlakeTerhune
What happens if you take out the semicolon at the end of the sql?
JoeBorgione
finally got this hack to give me what I want:
cn = mysql.connect(user = 'user', password = 'pwd', host = 'host', database = 'master_db')
cursor.execute("Show tables")
tables = cursor.fetchall()
for table in tables:
    cursor.execute(f"select * from master_db.{table[0]}")
    rows = cursor.fetchall()
    print(f'{table[0]}, {len(rows)}')
DanPatterson
so it was From from
BlakeTerhune
Wouldn't it be more efficient to use count() instead of reading all the data?
select COUNT(*) from owner.table_name
JoeBorgione
Yeah.  Perhaps.  Emphasis on HACK in my earlier post.  There comes a point where a guy says, "yep, good enough"....
BlakeTerhune
You do you, dude 😉
JoeBorgione
Among other things....
Soon I won't be able to say:
