Multiprocessing won't create feature classes
7960
25
04-01-2022 01:12 PM
Jay_Gregory
I'm trying to implement a fairly straightforward multiprocessing script that takes every polygon in a shapefile, tessellates into a grid, takes the center points of each grid square, and then clips the points by the original feature (since the tessellation generates a minimum bounding rectangle).  The tessellation feature class is never created so next step (FeatureToPoint) fails.  I don't understand - can someone help?
Even if I comment out all the arcpy commands except GenerateTessellation, the output is never actually created.
import multiprocessing
import os
import time
import arcpy
startTime = time.time()
basedir = r"C:\Users\Jay\Documents\ArcGIS\Projects\DataPrep"
scratchGDB = 'C:\\Jay\\data\data.gdb'
output = os.path.join(basedir, "grids.gdb")
features = os.path.join(basedir,"features.shp")
def multifunction(ft):
    import arcpy
    name = ft[0]
    extent = ft[1].extent
    print('Working on {}'.format(name))
    fl = arcpy.management.MakeFeatureLayer(features, "{}fl".format(name), where_clause=f"Name='{name}'")
    gdb = os.path.join(basedir, "{}.gdb".format(name))
    arcpy.management.CreateFileGDB(basedir, "{}.gdb".format(name))
    output=os.path.join(gdb, "{}grid".format(name))
    grid = arcpy.management.GenerateTessellation(output, Extent=extent, Shape_Type="SQUARE", Size="900 SquareMeters")
    print('tellessation')
    pointgrid = arcpy.management.FeatureToPoint(grid, os.path.join(scratchGDB, "{}pointgrid".format(apt)))
    arcpy.analysis.Clip(pointgrid, fl, os.path.join(output, f"{apt}Points"))
    arcpy.management.Delete(fl)
    arcpy.management.Delete(grid)
    arcpy.management.Delete(pointgrid)
def main():
    processList = [feature for feature in arcpy.da.SearchCursor(features, ['Name', 'SHAPE@'])]
    pool = multiprocessing.Pool(1)
    pool.map(multifunction, processList[0:10])
    pool.close()
    pool.join()
if __name__ == "__main__":
    print("Running")
    main()
    executionTime = (time.time() - startTime)
    print('Execution time in seconds: ' + str(executionTime))
Jay_Gregory
Thanks!  I wonder if they'd take on this bug.  The line executes, just not when implemented with multiprocessing.  Might be out of scope for them.
by Anonymous User
Not applicable
Give it a shot.  The worst they can say is no and maybe update the documentation to let folks know that it won't work in a multiprocessing process.
JoshuaBixby
MVP Esteemed Contributor
@Jay_Gregory, I ran your code as-is (except changing output location), and it runs fine on my machine with Pro 2.9.2.  The result is an 11MB or so shape file.
Jay_Gregory
@JoshuaBixby So the multiprocessing code worked for you?  Would you mind posting the exact code that you ran (there is lots of code I posted in this thread so curious what exactly you ran).  I'm curious what would be different that would have the multiprocessing work for GenerateTessellation.
Thank you!
JoshuaBixby
Here is your code I am just copying and pasting back
from processRun import multifunction
def main():
    pool = multiprocessing.Pool(processes=4)
    pool.map(multifunction, range(0,1))
    pool.close()
    pool.join()
    main()
My processRun file looks like:
import arcpy
def multifunction(num):
    arcpy.management.GenerateTessellation("C:\\Users\\jay\\Documents\\test.shp", "-86.809667396 33.5218054870001 -86.7009855469999 33.6051117490001", "SQUARE", "900 SquareMeters", 'GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision')
Jay_Gregory
Okay, well works for you, doesn't work for myself or Jeff.  I wonder what the differences between our environments are that might be causing this.
I'm on arcpy 2.9 build py37_arcgispro_32704.  Python 3.7.11  Windows 10.  Conda env arcgispro-py3.  I'm guess though it's probably not worth the effort to really figure out what's happening here and why it's working for some folks and not others.
