Multiprocess Geocoding
2295
08-04-2016 12:03 PM
MarcCusumano
Does anyone have a copy of the script that used to be found here:
Multiprocess Geocoding | ArcGIS Blog
This was a very handy script, and an example of how to implement multiprocessing.
Thanks.
BruceHarold
Esri Frequent Contributor
Hi
Impeccable timing, we removed the old tool that uses multiprocessing this morning, and the one Dan references is what I would currently recommend when you want to scale geocoding on a single machine.  If you have Server then you can go to the next level with this tool:
http://www.arcgis.com/home/item.html?id=e57a7f9b15de428ea33c62e00bfb2332
I'll add a comment on the blog post.
Regards
DanPatterson_Retired
BruceHarold
Hi
Regards
