Multiple rasters added together using python
8938
9
04-08-2011 12:12 AM
Heatherna
I am working on adding several rasters together then dividing them by the number of rasters added (to find the average)
Is it possible to call the raster calculator in a stand alone script? Is it even possible to do this outside of ArcMap (works fine in a model calling the raster, but the snippet of python code doesn't work when placed into a script that is run from IDLE or PythonWIN), or do I have to add two together at a time using Plus repeatedly.
I keep getting this error:
return _wrapLocalFunctionRaster(u"Plus_sa", ["Plus", in_raster_or_constant1, in_raster_or_constant2])
RuntimeError: ERROR 000824: The tool is not licensed.
I am using ArcGIS 10 and python 2.6.
Below is my code
import os, sys, arcpy
from arcpy import env as e
from arcpy.sa import *
a1 = Raster(r"D:\raster1.tif")
a2 = Raster(r"D:\raster2.tif")
a3 = Raster(r"D:\raster3.tif")
a4 = Raster(r"D:\raster4.tif")
outras = (a1+a2+a3+a4)/4
outras.save(r"D:\")
Am I missing an extension?
If I use:
outras = arcpy.RasterCalculator_sa(a1+a2+a3+a4)
I get the error:
AttributeError: 'module' object has no attribute 'RasterCalculator_sa'
Very frustrating.
Thanks in advance for any suggestions
Mac
DanPatterson_Retired
see the standalone script example in the help file, you need to checkout the extension
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z00000096000000.htm
Heatherna
Thanks, I tried that and I still get an error as follows:
File "C:\Python26\ArcGIS10.0\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 322, in RunScript
    debugger.run(codeObject, __main__.__dict__, start_stepping=0)
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\Pythonwin\pywin\debugger\__init__.py", line 60, in run
    _GetCurrentDebugger().run(cmd, globals,locals, start_stepping)
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\Pythonwin\pywin\debugger\debugger.py", line 655, in run
    exec cmd in globals, locals
  File "D:\average3.py", line 70, in <module>
Any other thoughts? I keep poking at it but its still not working
Heatherna
Resolved. I ended up ditching the raster calcuator and used the weightedsum tool instead
why not use the plus syntax
outPlus = Plus(inRaster1, inRaster2)
for further information
DarrenWiens2
I haven't tested this out, but the Raster Calculator help says the syntax is RasterCalculator(...) not RasterCalculator_sa (which is tricky - bad ESRI).
Heatherna
I needed to use more than two rasters, the plus tool only allows for two inputs.
RyanDeBruyn
Please note:
The help for the RasterCalculater in 10.0 states: The Raster Calculator tool is intended for use in the ArcGIS Desktop application only as a GP tool dialog box or in ModelBuilder. It is not intended for use in scripting and is not available in the ArcPy Spatial Analyst module.
The Raster Calculator is not supported in scripting because in ArcGIS 10 Map Algebra can be accessed directly when using the geoprocessing ArcPy site-package.  This seamless integration of Map Algebra into Python extends the capabilities of Map Algebra by taking advantage of Python and third party Python modules and libraries; making Map Algebra far more powerful than it has been in the past.
Reference:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000z7000000.htm
http://blogs.esri.com/dev/blogs/geoprocessing/archive/2010/04/28/the-new-and-improved-raster-calcula...
The solution to your problem:
1) You will need to checkout the Spatial Analyst License to use operators or any Spatial Aanlayst tools with rasters.
arcpy.CheckOutExtension('Spatial')
To obtain your average use one of the following.
A)
outras.save("averaster')
or
B)
outras = arpcy.sa.CellStatisitics([a1,a2,a3,a4], "MEAN")
outras.save("averaster")
Good luck,
-Ryan
Hannes_I_Reuter
Are you checking out the spatial analyst extension ?
Running code below!
import arcpy
arcpy.env.scratchWorkspace = "yourscratch"
arcpy.env.workspace = "yourworkspace"
arcpy.CheckOutExtension("Spatial")
final = (Raster('Raster_a_withpath' + Raster('Raster_b_with_Path' + ...) / 4
final.save(youroutrastername)
HTH
P.S.:keep in mind, there are strong differences between Single python and buildin python in AG10 syntax..
P.S.: type dir(arcpy.sa)  helps to identify the avaiable commands
P.S.P.S: help(Raster) helps to identify the syntax for a specific command
PS.PS: Don"t use the "FROM" keyword for example in Reclass Table as it is a Keyword in Python!
