Multiple Data Driven Frames Using Python
4403
8
08-04-2016 10:08 AM
Johnkelly4
I've been trying to write a script that can do the following:
Example:
-Two frames on a layout, one on top and one on the bottom
-10 data driven pages
-It would display DDP's 1, 3, 5, 7, 9 top frame and DDP's 2, 4, 6, 8, 10 on the bottom frame, for a total of 5 sheets of paper.
Below is what I have come up with so far. The script runs them one at a time instead of together. Anyone know what I am missing?
import arcpy
import time
mxd = arcpy.mapping.MapDocument("CURRENT")
#Lists all dataframes within the mxd
df1 = arcpy.mapping.ListDataFrames(mxd,"Layers")[0]
df2 = arcpy.mapping.ListDataFrames(mxd,"Layer 02")[0]
lyr = arcpy.mapping.ListLayers(mxd, "", df2)[0]
rows = arcpy.SearchCursor(lyr,"CATEGORY = 'Even'",
                          fields="Shape; Id; CATEGORY; Name",
                          sort_fields="Id A")
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1,2):
  mxd.dataDrivenPages.currentPageID = pageNum
  for row in rows:
    df2.extent = row.Shape.extent
    df2.scale = 2400
    arcpy.RefreshActiveView()
    time.sleep(2)
    print row.getValue("Name")
del mxd
DarrenWiens2
This seems to work using a modern cursor. This works for 'nice' data, but you may have to do some work if you're missing IDs or something.
>>> import time
... mxd = arcpy.mapping.MapDocument("CURRENT")
... df1 = arcpy.mapping.ListDataFrames(mxd,"Layers1")[0]
... df2 = arcpy.mapping.ListDataFrames(mxd,"Layers2")[0]
... index = 'buff' # my DDP index layer
... features = {row[0]:row[1] for row in arcpy.da.SearchCursor(index,['ID','SHAPE@'])} # all index features
... for pageNum in range(1,mxd.dataDrivenPages.pageCount,2):
...    mxd.dataDrivenPages.currentPageID = pageNum
...    df1.extent = features[pageNum].extent
...    df2.extent = features[pageNum+1].extent
...    arcpy.RefreshActiveView
...    time.sleep(2)
Johnkelly4
Thank you sir! Your version seemed to work (and was much cleaner). What exactly did you mean by 'nice' data and missing IDs? What kinds of problems do you see with this?
DarrenWiens2
It just doesn't actually read the available IDs. It assumes that every ID exists between 1 and the length of the list. If you happened to have IDs 1, 2, 3, 5 (missing 4), when the loop is on 3 it will look for value 4 (pageNum+1), but since it's not there, there will be an error. If all your IDs exist, there should be no problem.
Johnkelly4
Ah ok, I think I will be fine in that case. Will I be able to call on different field information with this? For example: I have a field called scale that determines the scale for each extent (1:2,400, 1:3,600, etc). So could something like this work:
import time
df2 = arcpy.mapping.ListDataFrames(mxd,"Layer02")[0]
fc = "D:\Practice\Arcpy\New_Shapefile.shp"
index = fc # my DDP index layer
            (index,['ID','SHAPE@','Scale'])} # all index features
    df1.scale = Scale
    df2.scale = Scale
    print ['ID']
    arcpy.mapping.ExportToPDF(mxd, r"D:\Practice\Arcpy\Page_" + str(pageNum) + ".pdf")
    time.sleep(2)
del mxd
DarrenWiens2
You would need to add the scale value into the features dictionary. Before, the dictionary had the form: {ID1:SHAPE1, ID2:SHAPE2,...}. Below, I've changed it to be like: {ID1:[SHAPE1,SCALE1], ID2:[SHAPE2,SCALE2]...}. So, later on, you can reference by ID (features[pageNum]) and get either the shape ([0]), or scale ([1]).
import time
features = {row[0]:[row[1],row[2]] for row in arcpy.da.SearchCursor
    df1.extent = features[pageNum][0].extent
    df1.scale = features[pageNum][1]
    df2.extent = features[pageNum+1][0].extent
    df2.scale = features[pageNum+1][1]
    print ['ID'
    time.sleep(2
del mxd
Johnkelly4
Thank you! It worked out great! Sorry I am new to arcpy. So just to make sure I understand what happened -
The dictionary part is this?: features = {row[0]:[row[1],row[2]]...       (row[0] is attached to 'ID' and row[1] to 'Scale'?)
This part specifies what goes in each row? (index,['ID','SHAPE@','Scale'])} # all index features
DarrenWiens2
Yes, this is the line that builds the dictionary. It uses some shorthand called a dictionary comprehension:
features = {row[0]:[row[1],row[2]] for row in arcpy.da.SearchCursor(index,['ID','SHAPE@','Scale'])}
This line is equivalent to:
features = {}
with arcpy.da.SearchCursor(index,['ID','SHAPE@','Scale']) as cursor:
    for row in rows:
        features[row[0]] = [row[1],row[2]] # I think this is right, but may get key error, I can't remember
And, yes, you're mostly right about which part specifies what in row. The first value ('ID') becomes the first item in row (row[0]), second value ('SHAPE@') goes into row[1], and third value ('Scale') goes into row[2]. If you listed more fields, they would go into row[3], row[4], etc.
Johnkelly4
Got it! Thanks again for all your help!!
