Move polyline endpoints using field calculator?
3056
6
08-20-2018 05:41 PM
AdelaideZumwalt1
How do I go about moving the endpoint of a polyline using field calculator? I have the x,y end point coordinates in the "X" and "Y" fields.
def XYsetVALUE(shape, X_value, Y_value):
point = shape.getPart(1)
point.X = X_value
point.Y = Y_value
return point
SHAPE = XYsetVALUE ( !SHAPE!, !X!, !Y!)
XanderBakker
Esri Esteemed Contributor
The fact that a polyline disappears when the Z value is invalid is behavior that I have seen before (recently also with ArcGIS Pro). I assume that the geometry is considered not to be valid.
So you could follow the advise of Joshua Bixby and use the cursor. Always test this on a copy to avoid loosing data, since that data is modified.
Here is a snippet of code that you could try. It will not process multipart polylines nor elements that have an invalid Z:
def main():
    import arcpy
    fc = r"path to a copy of your polyline features"
    fld_x = "X"
    fld_y = "Y"
    fld_z = "Z"
    flds = ('SHAPE@', fld_x, fld_y, fld_z)
    with arcpy.da.UpdateCursor(fc, flds) as curs:
        for row in curs:
            polyline = row[0]
            x = row[1]
            y = row[2]
            z = row[3]
            polyline = SetLastPointPolyline(polyline, x, y, z)
            curs.updateRow((polyline, x, y, z, ))
def SetLastPointPolyline(polyline, x, y, z):
    # BEWARE: it will not change multipart polylines or items with Z is None
    if polyline.isMultipart == True:
        return polyline
    elif z == None:
        return polyline
    else:
        sr = polyline.spatialReference
        lst_pnts = []
        for part in polyline:
            for pnt in part:
                lst_pnts.append(pnt)
        pnt_z = arcpy.Point(x, y, z)
        print lst_pnts
        lst_pnts[-1] = pnt_z
        print lst_pnts
        polyline = arcpy.Polyline(arcpy.Array(lst_pnts), sr, True, False)
        return polyline
if __name__ == '__main__':
    main()
The code is not tested. If you are able to share a part of your data I can test it.
XanderBakker
The point is that you can read the lastPoint from a Polyline, however, it is read only, so you can't set the new value. To do this you would have to loop over the points that construct the polyline and replace the last item. It is also important that you return a valid polyline that will be written to the featureclass.
I also notice that you have the Z value enabled of your polyline geometry. This will make it a little more complicated, but I guess that you could do this with the following snippet (if the line is not a multi part):
    lst_pnts = []
        for pnt in part:
    print lst_pnts
    print lst_pnts
    return polyline
AdelaideZumwalt1
Hi Xander,
The vast majority of my lines are not multipart, which is good. When I run it using a NULL z value the line disappears. When I set a z value it gives me the following error:
Codeblock:
XanderBakker
def main():
    import arcpy
    fld_x = "X"
    fld_y = "Y"
    fld_z = "Z"
        for row in curs:
            polyline = row[0]
            x = row[1]
            y = row[2]
            z = row[3]
        return polyline
    elif z == None:
        return polyline
    else:
        lst_pnts = []
            for pnt in part:
        print lst_pnts
        print lst_pnts
        return polyline
    main()
DanPatterson_Retired
elif z == None  OK
elif z is None Preferred
JoshuaBixby
MVP Esteemed Contributor
I typically use Update Cursors for such activities, I can't recall whether Field Calculator even let's someone update the geometry field.
You are calling getPart(1), are these multi-part lines?
AdelaideZumwalt1
No, they are not multipart. I used this blog to update point locations using field calculator successfully:
https://community.esri.com/groups/technical-support/blog/2011/12/06/how-to-update-the-location-of-a-...
