Modify CSV writer script to define list of columns by field name
9529
21
11-26-2021 02:27 AM
David_Brooks
MVP Regular Contributor
I have a script that writes a CSV based on fields from a feature class. Currently, the columns are defined by a field list, and a Search cursor loops through each item in the list to write to the CSV.
The list is defined by the positions of each field in the list. However, if the field order ever changes on the Feature Class, this list goes to pot.
How do I rewrite it so that I can define fld_list_final as a list of strings that match the actual field names, instead of their positions in the list?
So, for example, instead of the list being fn[5], fn[6] etc, i want to be able to define it as 'TreeRef', 'Species', etc
   # Create CSV of data for schedule if there are veteran trees
   import csv
   import os
   def tableToCSV(input_tbl, csv_filepath):
       fld_list = arcpy.ListFields(input_tbl)
       fn = [fld.name for fld in fld_list]
       fld_list_final = [fn[3], fn[4], fn[5], fn[6], fn[7], fn[8], fn[38], fn[41], fn[22], fn[23], fn[24], fn[25], fn[26], fn[27], fn[28], fn[29], fn[30], fn[36], fn[40], fn[39], fn[33], fn[37]]
       with open(csv_filepath, 'w', newline='') as csv_file:
           writer = csv.writer(csv_file)
           writer.writerow(fld_list_final)
           with arcpy.da.SearchCursor(input_tbl, fld_list_final) as cursor:
               for row in cursor:
                   writer.writerow(row)
       csv_file.close()
   out_csv = csv_path+"\\"+(os.path.basename(fc_pnt))+".csv"
   tableToCSV(fc_pnt, out_csv)
   arcpy.AddMessage("CSV Generated.")
David
..Maps with no limits..
Tags (3)
David_Brooks
in which case, i'll replace commas with semicolons before exporting. Might be the only way around it
David
DanPatterson
MVP Esteemed Contributor
Part 2  NumPy and Arcpy play nice: part 2 - Esri Community
more to come
... sort of retired...
