Model error- Converting CAD to FC
1617
02-23-2012 05:59 AM
Almuatasim_Ahmed_SaidAl-Hinai
Hi All,
I have created a model to batch extracting a particular DWG polyline layer to corresponding feature classes. I am getting the resultant polyline feature classes as PolylineZ. How can I modify my model to output feature classes of type Polyline instead of PolylineZ? I tried to disable the Z Values from the Environment Settings but I am getting the following error:
ERROR 999999: Error executing function.
Geometry cannot have Z values.
Failed to execute (Select).
A snapshot from my model is attached. Any help for solving this will be highly appreciated.
Thanks a lot
Asim
JakeSkinner
Esri Esteemed Contributor
Hi Asim,
It looks like this is a bug.  The Select tool does not honor 'Z Values' environment variable even though the help states that it does.  As a workaround, I would recommend using the 'Feature Class to Feature Class' tool.  You can apply a SQL Query when exporting the DWG file, and setting the 'Z Values' to 'Disabled' in the environment settings will be honored.
Thanks a lot Jskin3
FCtoFC solved my problem.
Really appreciating your help
Asim
