Model Builder to python. Error at calculate field function
1572
08-20-2020 02:22 PM
helenchu
All,
My model works fine but when I export it to python I got syntax error SyntaxError: "EOL while scanning string literal" .  Any idea why?  I've tried many simple calculation functions.  Got same errors for all.  Thank you!
EX:
# Process: CalField_Ac (Calculate Field) (management)
ToAcres = arcpy.management.CalculateField(in_table=FromSqft, field="Acres", expression="round((float(!Sqft!)/43560),4)", expression_type="PYTHON3", code_block="", field_type="TEXT")[0]
or
# Process: CalField_BlkNum (Calculate Field) (management)
Calculate_BlkNum = arcpy.management.CalculateField(in_table=myTable, field="Blk_Num", expression="fn(!Blk_Num!,!Acct_Num!)", expression_type="PYTHON3", code_block="def fn(Blk_Num,Acct_Num):
 if (Blk_Num) is not None:
 return Blk_Num
 else:
 return 1
 ", field_type="TEXT")[0]‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson
MVP Esteemed Contributor
Indentation is crucial for codeblocks.  Triple quotes helps
code_block = """
def fn(Blk_Num, Acct_Num):
        return Blk_Num
    return 1
... sort of retired...
DanPatterson
code_block = """
        return Blk_Num
    return 1
helenchu
That's it.  Triple quotes solved my issue.  Thank you so much Dan Patterson.
