import arcpy, os arcpy.env.workspace = "c:/junk" tableList = arcpy.ListTables() arcpy.Merge_management(tableList, "easy.dbf")In 9.x, it's much more involved.
Hallo,
that is a nice code snippet...I am new to python; how can I make a skript from this?
Yours
Matthias
>>> import arcpy, os ... arcpy.env.workspace = "C:\Users\admin\Desktop" ... tableList = arcpy.ListTables() ... arcpy.Merge_management(tableList, "easy.shp") ... Runtime error <class 'arcgisscripting.ExecuteError'>: Failed to execute. Parameters are not valid. ERROR 000732: Input Datasets: Dataset fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p0avk0p2_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p2avk0p4_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p4avk0p6_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p6avk0p8_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p8avk1p0_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p0avk1p2_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p2avk1p4_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p4avk1p6_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p6avk9p0_final.dbf does not exist or is not supported Failed to execute (Merge). >>>
Thank you, I will read through this...I tried your script with norma (yellow) tables...it was working very nicely; but with dbf tables...it is not working for me.
Here is the message:>>> import arcpy, os ... arcpy.env.workspace = "C:\Users\admin\Desktop" ... tableList = arcpy.ListTables() ... arcpy.Merge_management(tableList, "easy.dbf") ... Runtime error <class 'arcgisscripting.ExecuteError'>: Failed to execute. Parameters are not valid. ERROR 000732: Input Datasets: Dataset fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p0avk0p2_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p2avk0p4_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p4avk0p6_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p6avk0p8_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p8avk1p0_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p0avk1p2_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p2avk1p4_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p4avk1p6_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p6avk9p0_final.dbf does not exist or is not supported Failed to execute (Merge). >>>What could be the reason?
Thanx,
Matthias
>>> import arcpy, os ... arcpy.env.workspace = "C:/Users/admin/Desktop" ... tableList = arcpy.ListTables() ... arcpy.Merge_management(tableList, "easy.dbf") ... Runtime error <class 'arcgisscripting.ExecuteError'>: Failed to execute. Parameters are not valid. ERROR 000732: Input Datasets: Dataset fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p0avk0p2_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p2avk0p4_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p4avk0p6_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p6avk0p8_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg0p8avk1p0_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p0avk1p2_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p2avk1p4_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p4avk1p6_final.dbf;fglr_o_fr_500m_C280_RNW_u_v_vBETRAG_neu_flussschlauch_vg1p6avk9p0_final.dbf does not exist or is not supported Failed to execute (Merge). >>>
Thanx, but I still get an error:
Runtime error <class 'arcgisscripting.ExecuteError'>: Failed to execute. Parameters are not valid. ERROR 000732: Input Datasets: Dataset fglr78.dbf;fglrjk.dbf does not exist or is not supported Failed to execute (Merge).
import arcpy, os arcpy.env.workspace = "c:/junk/dbf/mergeEasy" tableList = arcpy.ListTables() arcpy.Merge_management(tableList, "easy.dbf")...on the data you posted and it worked fine for me.
