Merge_management and fieldmappings problem
3109
02-17-2016 08:06 AM
ChrisMatthews
I am using arcpy.Merge_management to combine 4 CSV files into SDE. I attempting to use fieldmappings to rename the field headers, and this is causing it to crash. I've not used fieldmapping with more than two datasets simaltaneously before...
The error is trapped by the try loop, but is returning no information. Any help would be appreciated.
try:
    if booContinue == True:
        fieldmappings = arcpy.FieldMappings()
        fieldmap1 = arcpy.FieldMap()
        fieldmappings.addTable(rg_Layer)
        fieldmappings.addTable(ox_Layer)
        fieldmappings.addTable(sn_Layer)
        fieldmappings.addTable(sp_Layer)
        fieldmap1.addInputField(rg_Layer,"field1")
        fieldmap1.addInputField(ox_Layer,"field1")
        fieldmap1.addInputField(sn_Layer,"field1")
        fieldmap1.addInputField(sp_Layer,"field1")
        fieldout1 = fieldmap1.outputField
        fieldout1.name = "PCODE"
        fieldmap1.outputField = fieldout1
        fieldmappings.addFieldMap(fieldmap1)
        arcpy.Merge_management([rg_Layer,ox_Layer,sn_Layer,sp_Layer], pc_layer, fieldMappings)
        msg = msg + "\n" + outname + " created"
except:
    msg = msg + "\n" + "error creating " + outname + " - " + "\n" + arcpy.GetMessages(2)
    booContinue = False
DanPatterson_Retired
Chris  does fieldmapping work manually with csv files?  The help files only makes reference to featureclasses/shapefiles in the help topic but doesn't indicate what it can be used for
FieldMappings—Help | ArcGIS for Desktop
ChrisMatthews
I've managed to get the Field_Mapping working, but as a massively complex (hard to read) parameter to the Merge_management tool - see below, so it does seem that it is possible to use field mapping with CSVs.
arcpy.Merge_management("rg_Layer;ox_Layer;sn_Layer;sp_Layer", GISLive_GISADMIN_AA_TEST_70, "Postcode \"Postcode\" true true false 255 Text 0 0 ,First,#,rg_Layer,Field1,-1,-1,ox_Layer,Field1,-1,-1,sn_Layer,Field1,-1,-1,sp_Layer,Field1,-1,-1;Quality \"Quality\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field2,-1,-1,ox_Layer,Field2,-1,-1,sn_Layer,Field2,-1,-1,sp_Layer,Field2,-1,-1;POBox \"POBox\" true true false 255 Text 0 0 ,First,#,rg_Layer,Field3,-1,-1,ox_Layer,Field3,-1,-1,sn_Layer,Field3,-1,-1,sp_Layer,Field3,-1,-1;TotalDPS \"TotalDPS\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field4,-1,-1,ox_Layer,Field4,-1,-1,sn_Layer,Field4,-1,-1,sp_Layer,Field4,-1,-1;ResDPS \"ResDPS\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field6,-1,-1,ox_Layer,Field6,-1,-1,sn_Layer,Field6,-1,-1,sp_Layer,Field6,-1,-1;ComDPS \"ComDPS\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field7,-1,-1,ox_Layer,Field7,-1,-1,sn_Layer,Field7,-1,-1,sp_Layer,Field7,-1,-1;POBoxDPS \"POBoxDPS\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field8,-1,-1,ox_Layer,Field8,-1,-1,sn_Layer,Field8,-1,-1,sp_Layer,Field8,-1,-1;Matched \"Matched\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field9,-1,-1,ox_Layer,Field9,-1,-1,sn_Layer,Field9,-1,-1,sp_Layer,Field9,-1,-1;Unmatched \"Unmatched\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field10,-1,-1,ox_Layer,Field10,-1,-1,sn_Layer,Field10,-1,-1,sp_Layer,Field10,-1,-1;XCoord \"XCoord\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field11,-1,-1,ox_Layer,Field11,-1,-1,sn_Layer,Field11,-1,-1,sp_Layer,Field11,-1,-1;YCoord \"YCoord\" true true false 4 Long 0 0 ,First,#,rg_Layer,Field12,-1,-1,ox_Layer,Field12,-1,-1,sn_Layer,Field12,-1,-1,sp_Layer,Field12,-1,-1;PCType \"PCType\" true true false 255 Text 0 0 ,First,#,rg_Layer,Field19,-1,-1,ox_Layer,Field19,-1,-1,sn_Layer,Field19,-1,-1,sp_Layer,Field19,-1,-1")
XanderBakker
Esri Esteemed Contributor
Wouldn't it be easier to use a csv reader and order fields (indexes to fields) manually. Just seems that using FieldMappings (if it works on CSV files as Dan mentions) makes it unnecessarily complex.
ChrisMatthews
It is ironic that it ends up more complex using Field_Mapping, I wanted to use it to keep things simply.
