Map Series getPageNumberFromName Error
1627
08-16-2023 07:20 AM
ScoutStanley
I am working on converting a python script from 2 to 3. I am having issue with figuring out an error related to map series "getPageNumberFromName".
Below is the Python 3 conversion for map series.
ms = lyt.mapSeries
lyt.mapSeries.refresh()
pageNumber = ms.getPageNumberFromName(PIN)
ms.currentPageNumber = pageNumber
 Here is the setup for (PIN)
cursor = arcpy.SearchCursor(SourceTable)
for i in cursor:
try:
print('Start time: ' + strftime('%H:%M:%S') +'\n')
PIN = i.getValue(SearchField)
NoQuotePIN = i.getValue(SearchField)
print('\tAnalyzing parcel PIN ' + NoQuotePIN + ' ...')
#Reference aprx and layers
aprx = arcpy.mp.ArcGISProject(r'....ProMigration\AgMap_Pro.aprx')
m = aprx.listMaps("AgMap")[0]
ParcelLayer = m.listLayers("Parcel*")[0]
AgUseLayer = m.listLayers("AgUse*")[0]
SoilLayer = m.listLayers("Soil*")[0]
Also in my script reference  lyt = aprx.listLayouts()[0] before map series section.
Below here is the python 2 script for data driven page. The PIN is the same exact setup but references python 2.
ddp = mxd.dataDrivenPages
ddp.refresh()
ddp.currentPageID = ddp.getPageIDFromName(PIN)
Below is the error I get when I run the script. What confuses me is the ValueError is the exact PIN that is being referenced within script.
ScoutStanley
Issue Resolved  - Unsure if it's a workaround or not, but anyway...
within my layout in Pro, I did the steps below and instead of selecting "none" I selected the field PIN referenced and that worked. Screenshot below is from bug-000136946
ScoutStanley
