Map Book script from ESRI exercise fails with Runtime error
3244
03-12-2011 10:42 AM
WilliamLord
I am working on the exercise " Creating a Map Book" from ESRI's online Help for v10. This is the link to the section that uses a python script.
[URL="http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Adding_title_and_overview_map_pages_to..."]
The script returns this error.
Runtime error <type 'exceptions.AttributeError'>: Invalid path
Anyone know why?
I was able to export the map to PDF in the prior step.
ChrisMathers
Well are you just copy-pasting from the help or are you changing the paths. It may just be that the path in your script doesnt exist. manually check em.
MollyWatson
I manually changed the paths and I still get that same error. Other times everything crashes and I get an ESRI send error report.  Any other ideas other than manually checking the paths?
JeffBarrette
I completely reproduced the directly structure with made up files and it all worked.  You must have a logical error somewhere in your file name or path.
Also - you mention that you get an crash report.  Are you running this from within ArcMap or as a stand alone script?
Jeff
