Making my script run faster
1446
11-08-2011 05:59 AM
AleydisG__Pere
I'm trying to get the fastest and most efficient script to take each feature in a shapefile (it's a 60x60m grid with 10 million features) as a mask to cut a DTM and apply the surface volume tool to each resulting raster.
This script needs 3 seconds per feature but bearing in mind that I have 10 million features this is too slow.
Any idea on how to improve it?
Thanks!
import arcpy
arcpy.CheckOutExtension("3D")
arcpy.CheckOutExtension("spatial")
Fishnet60x60 = arcpy.GetParameterAsText(0)
MDT15 = arcpy.GetParameterAsText(1)
Area2D3D_txt = arcpy.GetParameterAsText(2)
try:
    rows = arcpy.SearchCursor(Fishnet60x60)
    for row in rows:
        idvalue = row.getValue("ID_GRID")
        arcpy.MakeFeatureLayer_management(Fishnet60x60, Fishnet60x60 + "_layer", "\"ID_GRID\" = '" + idvalue + "'", "", "")
        arcpy.gp.ExtractByMask_sa(MDT15, Fishnet60x60 + "_layer", idvalue)
        arcpy.SurfaceVolume_3d(idvalue, Area2D3D_txt, "ABOVE", "0", "1", "0")
except:
    arcpy.AddMessage(arcpy.GetMessages(2))
AndrewChapkowski
You can try using Split Raster to break up your analysis into smaller parts instead of the mask tool.
See: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000009v000000
DuncanHornby
MVP Notable Contributor
Aleydis,
I use PyScripter as my Python development environment. I find running a script from the Python command line window in ArcMap slower than running it from the IDE environment.  Also if you have a multicore processor maybe you could try and utilise them all? There is a great blog article showing a simple example here.
Duncan
KimOllivier
Honored Contributor
Quite right to worry about the performance.
You certainly don't want 10 million featureclasses output, that will kill any file system.
The cup of coffee rule states:
"If any single process takes longer than a cup of coffee then interrupt it and find a better way."
Just don't run a geoprocessing tool inside a cursor.
Why do you have to call it for each feature?
Maybe just run the Polygon_Volume_3D tool once?
