MakeXYEventLayer Issues with .csv
1524
6
04-16-2014 12:37 PM
KarlRoth
Hello!
I have been working on plotting points on to a world map using latitude longitude coordinates in a .csv file, but they are always plotted in the wrong location.
Here is my code:
arcpy.MakeXYEventLayer_management('C:/FilePath.../SafeCastData.csv',"Latitude","Longitude","TestPlot",
[INDENT][INDENT][INDENT]u'GeographicCoordinateSystem/World/WGS 1984',"Value")[/INDENT] [/INDENT][/INDENT]
This plots them all at the south pole in the World Topology Basemap.
What Works:
Creating a geodatabase, importing csv file into a table, adding data to ArcMAP table of contents, and clicking Display XY... with all of the same settings as above.
Why does using a geodatabase work, but not a csv file? I really need a way to work on the file directly in the python code, and not through ArcMAP.
Thanks in advance!
AmyKlug
Try switching positions. Longitude is your X and latitude is your Y
KarlRoth
Great, Thanks! Now I am able to plot my data, but my PointToRaster_conversion() function is not showing up, and it is displaying the wrong values in the table of contents.
Displays values  3.40282e-038- 3.40282e+038 (I assume that's the max and min values allowed!)
My actual value range is from 20-40
I checked the attribute table of my point feature class, and all of the "Values" look fine...
Any idea what's going on here?
KarlRoth
Sorry I thought I added that part of the code. Here is my point to raster conversion:
arcpy.PointToRaster_conversion(feature class name, "Value", out data name, "MEAN", "Vaule", 10000)
Thanks!
IanMurray
Honored Contributor
Karl,
I'm not sure this is the problem, but I thought it was worth point out.
First you have a syntax error I'm assuming "Vaule" should be "Value".
Secondly, the 5th parameter, which is priority field should only be used when you use the MOST_FREQUENT cell assignment(4th parameter).  It should probably left just a blank string when you use "Mean" cell assignment.  This may or may not have anything to do with you getting the wrong values.
arcpy.PointToRaster_conversion(feature class name, "Value", out data name, "MEAN", "", 10000)
KarlRoth
Ian,
I tried all that, and it still didn't work. I can only get PointToRaster to work if I first use Display XY Data on a geodatabase, but both methods (Display XY Data and MakeXYEventLayer) create a multipoint feature class. What's going on here?
The weird thing is that I'm not getting any error messages. Just no output.
AmyKlug
Does it work using the point to raster geoprocessing tool?
