Loop through folder of MXD and change server name
2633
06-20-2019 11:40 AM
Brian_McLeer
MVP Regular Contributor
We are changing our production server to have a prefix of 'HV'. I have a folder of MXDs I would like to update to the new server, but I am missing something from my code below. I got my start from https://gist.github.com/davehorsey/d8892b150e61d2e03617
import arcpy, os
path = r"C:\layouts"
for fileName in os.listdir (path):
 basename, extension = os.path.splitext(fileName)
 # select MXD files that do NOT begin with "Copy_of_" - this
 # prevents the script from updating files that have already been updated
 if (extension == ".mxd") and (fileName[:8] != "Copy_of_"):
 fullPath = os.path.join(path, fileName)
 mxd = arcpy.mapping.MapDocument(fullPath)
 print fullPath
 # update data sources
 mxd.findAndReplaceWorkspacePaths("Database Connections\\Server Database NT Auth.sde", "Database Connections\\HV_Server Database NT Auth.sde")
 print "\tUpdated: SDE data sources"
 # check for broken links
 brknList = arcpy.mapping.ListBrokenDataSources(mxd)
 for brknItem in brknList:
 print "\tCheck: " + brknItem.name + " data source broken"
 if not brknList:
 print "\tCheck: no broken data sources"
 # save a copy of the MXD
 saveACopy_filename = "Copy_of_" + fileName
 saveACopy_fullpath = os.path.join(path, saveACopy_filename)
 mxd.saveACopy(saveACopy_fullpath)
 print "\tSaved: " + saveACopy_filename
 del mxd
 # delete the original MXD
 arcpy.Delete_management(fullPath)
 print "\tDeleted: " + fullPath‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JakeSkinner
Esri Esteemed Contributor
I haven't test, but you could try the following:
import arcpy, os
from arcpy import env
from arcpy import mapping
# Parent directory to MXDs.  Script will iterate through Child directories
env.workspace = r"D:\Temp\Python\MXDs"
# New Enterprise Geodatabase
newDataSource1 = r"Database Connections\[email protected]"
newDataSource2 = r"Database Connections\[email protected]"
newDataSource3 = r"Database Connections\[email protected]"
env.overwriteOutput = True
for (path, dirs, files) in os.walk(env.workspace):
    for file in files:
        if ".mxd" in file.lower():
            mxd = os.path.join(path, file)
            print(mxd + " is being processed")
            mxd = mapping.MapDocument(mxd)
            for df in mapping.ListDataFrames(mxd, "*"):
                for lyr in mapping.ListLayers(mxd, "*", df):
                    try:
                        if lyr.supports("DATASOURCE"):
                            if lyr.serviceProperties['Database']:
                                print("\tUpdating " + str(lyr))
                                try:
                                    lyr.replaceDataSource(newDataSource, "SDE_WORKSPACE", "")
                                    print("\tSuccessfully updated data source")
                                except:
                                    try:
                                        lyr.replaceDataSource(newDataSource2, "SDE_WORKSPACE", "")
                                    except:
                                        try:
                                            lyr.replaceDataSource(newDataSource3, "SDE_WORKSPACE", "")
                                        except:
                                            print("\tCould not update " + str(lyr))
                                            pass
                    except AttributeError:
                        pass
            mxd.save()
del mxd
JakeSkinner
Hi Brian,
I've had success with the following script.  It will iterate through a directory and child directories and update all database connections with the one specified in the newDataSource variable.
import arcpy, os
newDataSource = r"Database Connections\[email protected]"
    for file in files:
                    try:
                        pass
            mxd.save()
del mxd
Brian_McLeer
Thanks, Jake,
That worked for one data source, unfortunately, I have 3 databases referenced in the MXDs. Is there an 'if else' statement to point it towards the next database if the first one does not work?
Brian_McLeer
I should say if the first database connection does not contain the layer to reference to, but the layer is in the next database.
JakeSkinner
import arcpy, os
    for file in files:
                    try:
                                try:
                                except:
                                    try:
                                    except:
                                        try:
                                        except:
                                            pass
                        pass
            mxd.save()
del mxd
Brian_McLeer
Thanks Jake,
You saved me a bunch of time!
