Loop for exporting shapefiles from an existing shapefile
9476
15
03-18-2015 08:26 AM
KONPETROV
​Hello i have a pnt shp with 50 pnts. I want to export each one of it in a separate shapefile with arcpy writting a loop. My problem is that i want the output name i create to have a different name, e.g. for 1st pnt i want the output layers' name  to be pnt1_lyr, for the 2nd point, pnt2_lyr etc. I wrote that code but i always have an error. Can someone correct me;
import arcpy
arcpy.env.workspace = "c:/Wing/Sk"
for i in range(0, 49):
    arcpy.MakeFeatureLayer_management("spatially50.shp", "pnt_" + i + "lyr", "FID = i")
Thank you very much
IanMurray
Honored Contributor
actually FID is a numeric field, so a str(i) there would crash the query clause, since its comparing a number to a string.
I made some sample data and tested the following that works.
import arcpy
for i in range(0, 50):
  where_clause = "FID = {}".format(i)
  arcpy.FeatureClassToFeatureClass_conversion("spatially50", "c:/Wing/Sk", "pnt" + str(i), where_clause)
Formatting queries in python can be annoying, string formatting makes this much easier.
I usually refer back to this thread for properly creating SQL queries Python - Select by attributes query issue
DarrenWiens2
No. " FID = " + str(i) results in a whereclause of " FID = 0 " (desired) not " FID = '0' " (what you predict). Your method may work, but so does mine.
IanMurray
Honored Contributor
Sorry you were completely right about that, and to boot its faster since you aren't setting a variable each time.
KONPETROV
i was missing that: "FID=" + str(i). For God that was really helpfull, thank you for your try Mr. Wiens.
JoshuaBixby
MVP Esteemed Contributor
If you are only working with Points, another approach is to use the new NumPy-based features that were introduced with the ArcPy data access (arcpy.da) module.
import os
import numpy as np
in_features = #Point data set to have exported as individual data sets
out_path = #Path to geodatabases or folder for individual data sets
out_prefix = 'pnt_'  #Prefix for individual data sets, can be empty ''
desc = arcpy.Describe(in_features)
SR = desc.spatialReference
OID_name = desc.OIDFieldName
shape_name = desc.ShapeFieldName
narr = arcpy.da.FeatureClassToNumPyArray(in_features, "*")
ndtype = narr.dtype
for row in narr:
    n = np.array(row, ndtype)
    OID = n[OID_name]
    arcpy.da.NumPyArrayToFeatureClass(n,
                                      os.path.join(out_path, out_prefix + str(OID)),
                                      shape_name,
                                      SR)
The above script will work on shape files and feature classes because I am using an arcpy.Describe object to retrieve the name of the unique identifier and shape fields.
KONPETROV
Thank you a lot Mr. Bixby
