Local variables in SQL statement of Python GIS
1388
10-27-2011 01:27 PM
xiaojiabao
What is the appropriate format to use local variables in SQL statements under python GIS?
I came across error messages when I'm running the following:
bas=24
gp.Select(input, Output_Feature_Class, "\"BAS\"= bas")
However, it is ok if I run: gp.Select(input, Output_Feature_Class, "\"BAS\"= 24")
Appreciate any potential help.
Xi
LoganPugh
You can't use local variable names directly -- you have to use string formatting or concatenation.
E.g.
bas=24
whereClause = "\"BAS\"= %d" % (bas)
gp.Select(input, Output_Feature_Class, whereClause)
xiaojiabao
Thanks Logan,
That solved.
