Local Server GeoprocessingJob Fails
1200
11-10-2023 01:29 AM
Muhammadkhalid
I have generated a .gpkx package using a custom tool that accepts a .lyr file as input and produces a layer as output. The tool runs successfully in ArcGIS Pro, and the .gpkx is created without any issues. However, when attempting to use the .gpkx in my WPF application through a local runtime server, the GeoprocessingJob encounters failures. Can anyone provide insights or suggestions on resolving this issue?
Actually I want to display Layers from .lyr file in my WPF application using ArcGIS Maps SDK.Net but as there is no direct way to load .lyr file in Maps SDK so I am trying to create a .gpkx to load layer using Local Server.
Follwoing is arcpy code from which .gpkx was generated
import arcpy
import os
def script_tool(inputlyrfile, inputprojectpath, outfolderpath, outputlyr):
arcpy.env.workspace = outfolderpath
projName = "mmpkproject"
projNamewithPath = os.path.join(outfolderpath, f"{projName}.aprx")
outmpkxfilepath = os.path.join(outfolderpath, "mpkxpackagefile.mpkx")
aprx = arcpy.mp.ArcGISProject(inputprojectpath)
newMap = aprx.createMap("mmpkmap", "Map")
insertLyr = arcpy.mp.LayerFile(inputlyrfile)
newMap.addLayer(insertLyr)
insertLyr.saveACopy(outputlyr)
del aprx
return
if __name__ == "__main__":
inputlyrfile = arcpy.GetParameterAsText(0)
outfolderpath = arcpy.GetParameterAsText(1)
inputprojectpath = arcpy.GetParameterAsText(2)
outputlyr = arcpy.GetParameterAsText(3)
Following are input/output parameters set in Tool properties
In my WPF application I am following the ArcGIS Maps sdk sample to consume the .gpkx using Local Server but GeoprocessingJob is failing.
private LocalGeoprocessingService _gpService;
private GeoprocessingTask _gpTask;
private GeoprocessingJob _gpJob;
private async void BtnGeoProcessing_Click(object sender, RoutedEventArgs e)
LocalServer.Instance.AppDataPath = "C:\\EsriSamples\\AppData";
await LocalServer.Instance.StartAsync();
_gpService = new LocalGeoprocessingService("path of .gpkx file", GeoprocessingServiceType.AsynchronousSubmitWithMapServiceResult);
_gpService.StatusChanged += GpServiceOnStatusChanged;
await _gpService.StartAsync();
private async void GpServiceOnStatusChanged(object sender, StatusChangedEventArgs statusChangedEventArgs)
    if (statusChangedEventArgs.Status != LocalServerStatus.Started)
return;
    try
        string strUrl = _gpService.Url + "/myscripttool";
        _gpTask = await GeoprocessingTask.CreateAsync(new Uri(strUrl));
        RunJob();
    catch (Exception ex)
        MessageBox.Show(ex.Message);
private void RunJob()
    GeoprocessingParameters gpParams = new GeoprocessingParameters(GeoprocessingExecutionType.AsynchronousSubmit);
    string strInputLayer = "D:\\data\\input\\somelayer_LYR.lyr";
    string strInputProjectFilePath = "D:\\data\\input\\templateproject\\templateproject.aprx";
    string strOutFolder = "D:\\data";
    gpParams.Inputs["inputlyrfile"] = new GeoprocessingString(strInputLayer);
    gpParams.Inputs["outfolderpath"] = new GeoprocessingString(strOutFolder);
    gpParams.Inputs["inputprojectpath"] = new GeoprocessingString(strInputProjectFilePath);
_gpJob = _gpTask.CreateJob(gpParams);
    _gpJob.StatusChanged += GpJobOnJobChanged;
    try
        _gpJob.Start();
private async void GpJobOnJobChanged(object o, JobStatus e)
    if (_gpJob.Status == JobStatus.Failed)// HERE JOB FAILS
        MessageBox.Show("Job Failed");
        return;
    if (_gpJob.Status != JobStatus.Succeeded)
{ return; }
    string gpServiceResultUrl = _gpService.Url.ToString();
    string jobSegment = "MapServer/jobs/" + _gpJob.ServerJobId;
    gpServiceResultUrl = gpServiceResultUrl.Replace("GPServer", jobSegment);
    VM.LblStatus += Environment.NewLine + "Creating layer from job result ";
    ArcGISMapImageLayer myMapImageLayer = new ArcGISMapImageLayer(new Uri(gpServiceResultUrl));
    try
        await myMapImageLayer.LoadAsync();
        Dispatcher.Invoke(() =>
            MainMapView.Map.OperationalLayers.Add(myMapImageLayer);
Muhammadkhalid
import arcpy
import os
del aprx
return
Following are input/output parmeters set in Tool properties
return;
    try
        RunJob();
    try
        _gpJob.Start();
    if (_gpJob.Status == JobStatus.Failed) // HERE JOB FAILS
        return;
{ return; }
    try
