Load features from file or mobile geodatabase into non-GDB enterprise database FC
1314
01-09-2024 04:46 AM
Bud
Legendary Contributor
ArcGIS Pro 3.2.1; Oracle Express 18c; the database is not a geodatabase (no ArcGIS Server or Enterprise)
In a related post, we established that the Append tool can’t be used to load data into an unregistered feature class.
As @MarceloMarques mentioned in that post, I’m wondering if there is a way to use Python to load features from a mobile or file geodatabase FC into the non-GDB enterprise database FC.
Is there a way to do that with Python? Thanks.
BlakeTerhune
I've used cx_Oracle, now pyhton-oracledb, to do SQL specific stuff. You could use PL/SQL insert statements into your db table. You might even be able to use an arcpy insert cursor, worth a try. There's also ArcSDESQLExecute, which may or may not work.
MarceloMarques
@Bud
Q:  I’m wondering if there is a way to use Python to load features from a mobile or file geodatabase FC into the non-GDB enterprise database FC.
A: there are many Oracle Tutorials available that teach how to access an Oracle database via python.
Python and Oracle Database Tutorial: The New Wave of Scripting
Developing Python Applications for Oracle Database
TIP: you can also explore Safe Software FME Workbench and FME Server for this task, it will not require to write any code with FME, FME works like ArcGIS Pro Model Builder and ArcGIS Pro Data Interoperability. Extension.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
