Load database rows into Python List or Dictionary?
24365
08-26-2012 11:49 PM
JamesMorrison1
SDE 9.3.1
ArcGIS/Catalog 9.3.1
Python 2.5
Oracle 11.1.0.6.0
Using gp.CreateObject("ARCSDESQLEXECUTE", <conn_name>)
Table: T_TRANSFER
OBJECTID NUMBER(38)
FC_NAME TEXT(50)
FC_NAME_2 TEXT(50)
FC_NAME_3 TEXT(50)
TRANSFER_DATE (DATE)
SQL = SELECT * FROM T_TRANSFER ORDER BY FC_NAME
I'm a little new to Python and was wondering how you can read records from a Table in Oracle (SDE) into a List (?) or Dictionary(?) or "something-else" so I can reuse it later in my code.
Pseudo-code
[1] Load rows into Dictionary or List or "something-else"?
Later in code???
[2] Loop through rows make data count on Feature Classes named in Colum "FC_NAME"
[3] Loop through rows make delete on Feature Classes named in Colum "FC_NAME"
[4] Loop through rows make delete on Feature Classes named in Colum "FC_NAME_2"
Steps [2], [3] and [4] are ok to code - I just seem to be having issues in [1] and then making a reference to loop through rows.
Can anyone help?
KevinBell
Look up the arcmap help on search cursors.  Once you have you value from the cursor you can append it to a list, or stick it in a dictionary.
SteveXu
Have you tried cx_Oracle extension? You can google on how to get cx_Oracle for python, make sure for your Oracle and python versions. Look at this http://www.oracle.com/technetwork/articles/dsl/python-091105.html. I used cx_Oracle with python, and found it is good to manipulate attribute data in oracle tables.
JamesMorrison1
ok. This seems to work. Perhaps there are better ways?
def getFeatureClasses(schema, table, attribute, project_model):
    dictFeatures = {}
    sql_val = "SELECT OBJECTID, " + attribute + " FROM " + schema + "." + table + " WHERE PROJECT_MODEL = '" + project_model + "' ORDER BY OBJECTID DESC"
    # read value
    print "SQL: " + sql_val
    WriteOutLine("SQL: " + sql_val)
    sdeReturn = sdeConn.Execute(sql_val)
    for row in sdeReturn:
        print row
        fID = row[0]
        dictFeatures[fID] = row
    return dictFeatures
# ----------------   Back up to Load ready for loading
error_msg = "ERROR: Back up to Load ready for loading."
try:
    fcsDict = getFeatureClasses("GEO", "TRANSFER", "FC_NAME", project_model)
    keyFeatures = fcsDict.keys()
    keyFeatures.sort()
    for key in keyFeatures:
        row = fcsDict[key]
        from_feature_class = row[1]
        data_backup(DATA_CONN_FOLDER, LOAD_DIR, FGDB_from, sSchema_to, sSDEconn_to, from_feature_class)
except OSError, (errno, strerror):
    print ERROR_STR % {'path' : error_msg, 'error': strerror }
