Listing data in an SDE
3874
03-13-2014 06:48 AM
Zeke
Honored Contributor
I wrote the code below to list datasets and associated feature classes and shape types (point, polygon, etc.) in an sde. This works fine until I get to the last dataset, Zoning, which contains one feature class and one topology. There, it errors out with "RuntimeError: DescribeData: Method feature type does not exist". Also errors on shapeType if I don't check featureType first.
Guessing this has something to do with desc not liking the topology, but is there a way around this other than catching the exception and then continue? Thanks.
def getLists():     dsList = arcpy.ListDatasets("*")     for ds in dsList:         dsName = ds.split(".")         print dsName[2].upper()          print " - Feature Classes"         fcList = arcpy.ListFeatureClasses("*", "", ds)         if len(fcList) == 0:             print "\t - " + "No feature class in this dataset. \n"             continue         for fc in fcList:             desc = arcpy.Describe(fc)             if desc.featureType == "Simple":                 fcName = fc.split(".")                 desc = arcpy.Describe(fc)                 print "\t - " + fcName[2] + ": " + desc.shapeType         print "\n"
ShawnThorne
When you're listing the Feature Datasets, you're specifying an asterisk (*) - which is getting everything.  Try specifying ("*", "Feature") to list just the Feature Classes.
dsList = arcpy.ListDatasets("*","Feature")
Here's a script I wrote that lists all of the Feature Datasets (and the Feature Classes contained within them, with their geometry type) in an SDE/Oracle instance.  Just modify the name of the connection file for the SDE user.
Hope this helps.
-Shawn
 import arcpy, gc  # Write results to a textfile logfile = open(r'C:\TEMP\List_FCs_in_FDs.log', 'w')   def log_results(message):     print(message)     logfile.write(message)     logfile.flush()     return  def main():     try:          EGDB = arcpy.env.workspace = r'Database Connections\ORCL - [email protected]'                  fdList = arcpy.ListDatasets("*", "Feature")          fdCnt = 0         totalFCcnt = 0          if arcpy.Exists(EGDB) == True:              for eachFD in sorted(fdList) :                 fdCnt += 1                 log_results("\n {0}. Feature Dataset '{1}'\n".format(str(fdCnt),eachFD))                 fcCnt = 0                  # Cannot use  fdEGDB = EGDB + '/' + eachFD  returns Cartesian Product                 fdEGDB = arcpy.env.workspace = EGDB + '/' + eachFD                 fcList = arcpy.ListFeatureClasses("*")                 for eachFC in sorted(fcList):                     desc = arcpy.Describe(eachFC)                     log_results("   -> " + eachFC + ' (' + desc.shapeType + ')')                     fcCnt += 1                     totalFCcnt += 1                  if fcCnt == 0:                     log_results("\n   Feature Dataset '{0}' does not contain any Feature Classes!!\n".format(eachFD))                 else:                     log_results("\n   # of Feature Classes in the '{0}' Feature  Dataset : {1}\n".format(eachFD,str(fcCnt)))               log_results("\n TOTAL # OF FEATURE DATASETS COUNTED : {0}".format(str(fdCnt)))             log_results(" TOTAL # OF FEATURE CLASSES COUNTED  : {0}\n".format(str(totalFCcnt)))          else:             log_results("\n The specified SDE Connection File DOES NOT EXIST\n")             return          log_results ("\n\n COMPLETED!! \n\n")          del fcCnt         del fdCnt         del fcList         del fdList         del fdEGDB         del eachFD         del totalFCcnt          gc.collect()      except arcpy.ExecuteError:         log_results (arcpy.GetMessages(2))      except Exception as e:         log_results (e[0])  if __name__ == '__main__':     main()
JoshuaChisholm
Hello Greg,
I'm not sure if this is satisfactory, but you could skip over the topology.
if desc.dataType=='Topology':
    continue
(Just make sure this line goes before the lines that error out)
Let me know if it works for you!
Zeke
Honored Contributor
Thanks Joshua. That fix, as well as the try/catch, stops the error but doesn't print the one feature class that is in the dataset. Hmmm...
ShawnThorne
Hope this helps.
-Shawn
Zeke
Honored Contributor
Thanks Shawn.
