Listing all feature classes in an Enterprise Database
2771
11-27-2022 07:44 PM
Thiru_P
Hi all,
TLDR; how do you create a list of data sets that lists everything in an enterprise geodatabase, schemawise?
I would like to generate a list of all the data sets (e.g, relationship classes, tables, feature classes, including the feature classes within Feature Datasets) in an enterprise database in each schema (.sde connection file) periodically.
I have used the arcpy.da.Walk module with keyword "Any" and with each datatype mentioned; no success yet.
Software used:
Python 3.7.11
PostgresSQL 11.16
PostGIS 2.4.5
ArcSDE Geodatabase 10.7.1
This is the code that I tried so far.
# -*- coding: utf-8 -*-
Lists the contents of Cloud Enterprise DataBase (CEDB) and writes into an MS Excel
Sorts in an alphabetical ascending order
Created on  09 May 2021
Last update 24 Nov 2022
@author: thiru
#List the contents of CEDB UAT
#import modules
import arcpy
import pandas as pd
import re
import openpyxl
#assign maximum processing power
arcpy.env.parallelProcessingFactor = "100%"
###List the folder where the sde connection files are
sdeDir = r"C:/SDE/"
##CEDB schemas as sde connection files
workspaceList = [
"alpha@cedb(uat).sde",
"beta@cedb(uat).sde",
"gamma@cedb(uat).sde",
"theta@cedb(uat).sde"
vardatatype = [
'CadDrawing',
'CadastralFabric',
'Container',
'FeatureDataset',
'FeatureClass',
'GeometricNetwork',
'LasDataset',
'Layer',
'Locator',
'Map',
'MosaicDataset',
'NetworkDataset',
'PlanarGraph',
'RasterCatalog',
'RasterDataset',
'RelationshipClass',
'RepresentationClass',
'Style',
'Table',
'Terrain',
'Text',
'Tin',
'Tool',
'Toolbox',
'Topology'
#create empty sets, this will remove duplicates
files = []
schemas = []
#iterate through each schema and list contents
for ws in workspaceList:
    workspace = sdeDir + ws
    da_owner= ws[:ws.index("@")]
    print (workspace)
    schemas.append(workspace)
    for dt in vardatatype:
        walk = arcpy.da.Walk(workspace, datatype=[dt])
        for dirpath, dirnames, filenames in walk:
            for filename in filenames:
                filename.lower()
                filename = filename+"."+dt
                files.append(filename)
                print(filename)
df = pd.DataFrame(files)
print("Number of features", len(files))
print("Number of schemas", len(schemas))
#Check if dataframe is empty
if df.empty:
    print('List is empty!')
else:
    # dropping null value columns to avoid errors
    df.dropna(inplace = True)
    #Name the column name
    df.columns = ['LayerName']
    df[['DbName', 'SchemaName', 'Layer', 'DataType']] = df['LayerName'].str.split('.', expand=True)
    #Remove the redundant column
    df = df.drop(columns=['LayerName'])
    #Sort the columns based on Schema, LayerName
    df.sort_values(by=['SchemaName', 'Layer'], ascending=(True, True), inplace=True, ignore_index=True)
    df.to_excel(r"C:/Temp/Lists/CEDB_alltypes_Listing.xlsx", index = False)
JohannesLindner
Your code works perfectly for me. What problems do you encounter?
Have a great day!
Johannes
Thiru_P
Thank you for trying the code.
Did it list the FeatureDatasets and the FeatureClasses inside Feature Datasets?
RhettZufelt
MVP Notable Contributor
Does not add the Feature Dataset to the Excel file, but it finds them and adds the contained Feature Classes.
R_
