listGeodatabases()
5754
10
02-06-2011 11:46 PM
LotharUlferts
I'm trying to create a listGeodatabases() method, simular to the gp.listxx-family.
All works fine, except this:
I can't differ a *.mdb created by Access from those created by ArcCatalog.
gp.describe(databasePath).DataType always returns 'Workspace'.
Can anyone help?
LotharUlferts
Hy,
after a long time I fond a soloution in the workspace 'release'-property:
arcpy.Describe(PGDB-WS)  returns something like u'3,0,0'
while arcpy.Describe(pure_MSACCESS-WS) returns somethinge like this u'400558244,2616584,323869160'
That's ok for me.
AndrewChapkowski
Check out the ListWorkspaces() and Describe data.
ListWorkspaces() allows you to specify if you want to find file geodatabase, personal geodatabase, sde, etc...
You can also use Describe() to get the workspace properties also.
LotharUlferts
hi andrew, thanks for your speedy reply.
Thats the goal: To differ ACCES-MBS from ArcGIS-MDBs.
gp.ListWorkspaces('*','Access') returns both typs.
I couldn't find a property on which an ACCES-MDB gives another value then the ArcGIS-MDB.
I tested this on the data in the attached example.zip.
AndrewChapkowski
I don't believe there is any difference between the MS Access databases. If it's created by esri or if it's create my MS Access, it's all the same file.  The difference is that a spatial database has a specific set of tables in it.
You can try using a library like pyodbc and look at the tables in the database.  If it has the spatial tables, then you know it's a spatial personal geodatabase.
Another solution too, would be to use file geodatabases to store spatial data instead of personal geodatabases.
LotharUlferts
I don't believe there is any difference between the MS Access databases. If it's created by esri or if it's create my MS Access, it's all the same file.  The difference is that a spatial database has a specific set of tables in it.[....] Another solution too, would be to use file geodatabases to store spatial data instead of personal geodatabases.
Unfortunatly my script is operating in folder with unknown content. And in each GDB of this folder one FeatureClass has to be created to summerize something. DBs created with Access causes an error.
That's a good solution. I try this  hint and perhaps I can announce a solution.
NiklasNorrthon
Why not just try to create that feature class, and if it doesn't work, just assume it's an access db. Something like:
mdb_list = gp.ListWorkspaces('*', 'Access')
for each mdb in mdb_list:
    try:
        gp.CreateFeatureClass(your_arguments)
    except WhateverExceptionYouGetWithWrongTypeOfMDBs:
        pass # Just ignore (or maybe you should log something)
LoganPugh
    try:
This seems error-prone and potentially very slow.
ESRI should provide a built-in method to determine whether an MDB file is a PGDB or a regular Access database.
See also:
Finding All Geodatabases Inside Main Folder and Subfolders
RDHarles
Add this simple line of code to check for Access:
if gdb.endswith(".mdb"):
LoganPugh
That will still return true for both personal geodatabases which are Access-based and use the .mdb file extension, and plain Access MDB databases which are not geodatabases.
LotharUlferts
Hy,
That's ok for me.
