ListFeatureClasses returns '[ ]'
1540
09-17-2013 05:36 PM
StephenPage
I'm not able to get the ListFeatureClasses working!
This is a pretty basic code, and I've seen many examples, including in the ESRI 10.1 Help
Note that 'Exists' works!
But not ListFeatureClasses, ListDatasets, ListFiles... - these return '[ ]'
Files are on my C drive (local Hard drive)
Steve
import arcpy
from arcpy import env
env.workspace = "C:/drainagescripting/inputdata/drainagedatasp.gdb"
# THIS WORKS - prints 'true'
print arcpy.Exists("C:/drainagescripting/inputdata/drainagedatasp.gdb")
# THESE return '[ ]'
fclist = arcpy.ListFeatureClasses()
print fclist
jp
If the feature classes reside in feature dataset then you need to include the feature dataset name in the path.
RebeccaStrauch__GISP
I'm not sure why it wouldn't work for you, assuming there is actually some feature classes in the .gdb.
I modified you code slightly
import arcpy
env.workspace = theWorkspace = "C:/__temp/test.gdb"
print arcpy.Exists(theWorkspace)
print (fclist)
and my results were..
True
[u'newpts', u'newPtsMySR', u'test', u'testout2', u'StudyZones', u'bl00_point']
so, take a look at your .gdb to see what is in there.
