ListDatasets problem with Geoprocessing Service
2895
10-30-2014 07:51 AM
Mohamed_MagdyMohamed_Hussain
I create a Python Script as Show below to print the list of Datasets in arcpy.AddMessage() this script run successfully for (*.gdb, *.sde) but when publish this script as Geoprocessing Service it work successfully for (*.gdb) only and return empty list for (*.sde).
Note: The two workspaces I used as “E:\WSTest.gdb” and “E:\WSTest.sde” where SDE is for SQL Server Express 2008R2
WS_in is string for the path of Workspace
import arcpy
WS_in = arcpy.GetParameterAsText(0)
arcpy.env.workspace = WS_in
arcpy.AddMessage(arcpy.env.workspace)
lst = arcpy.ListDatasets()
arcpy.AddMessage(lst)
for i in lst:
    arcpy.AddMessage(i)
DallasShearer
you might need to register the database connection on the server.
Here's a link in case you are unfamiliar with this setup.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
DallasShearer
Thank you it work
