List Feature Classes within Subfolders using Python
10852
01-06-2011 07:16 AM
TomJansen
I'm trying to get a list of feature classes in a folder and it's subfolders.  Below is a script that gets just the folder specified.  Any help on how to loop through the subfolders is appreciated.
import arcpy
from arcpy import env
import os
# Set the workspace for the ListFeatureClass function
env.workspace = "C:/Data"
# Use the ListFeatureClasses function to return a list
fcList = arcpy.ListFeatureClasses()
print fcList
JasonScheirer
Esri Alum
You could use a generator in this case:
import arcpy
import os
def fcs_in_workspace(workspace):
  arcpy.env.workspace = workspace
  for fc in arcpy.ListFeatureClasses():
    yield os.path.join(workspace, fc)
  for ws in arcpy.ListWorkspaces():
    for fc in fcs_in_workspace(os.path.join(workspace, ws)):
        yield fc
for fc in fcs_in_workspace("C:/Data"):
Or you could do something like
fclist = list(fcs_in_workspace("C:/Data"))
and reuse it.
JasonScheirer
Esri Alum
import arcpy
import os
    print os.path.join(workspace, fc)
ChristinaHerrick1
How would you then iterate through the list later in the script?
Ex. "for fc in fclist: ..."
JasonScheirer
Esri Alum
import arcpy
import os
        yield fc
and reuse it.
ChristinaHerrick1
Awesome!  Thanks!
JeffBigos
Hi All,
I wanted to add to additional ways to accomplish this and apply it to different data types.
I teach Python for Esri and have had this question come up in class alot.
1. Arcpy.da.walk:
     This was introduced to the data access module at 10.1 SP1
     ArcGIS Help (10.2, 10.2.1, and 10.2.2)
     Where this function is nice is in 2 parameters
     Datatype: the value set here is the filter for what is returned as walk traverses the subfolders
     type: not for all datasets, but at least you could specify point, line, poly or raster types
     Look at the Sample script 1 in the documentation
2. python os.walk:
     this function will perform the same type operation gathering subfolders and files
     The one difference is this won't retrieve contents inside of a geodatabase.
     This could be used if you script involved python code with out the use of arcpy
     maybe you needed to find all the .xls files under a D:\projects folder.
     15.1. os — Miscellaneous operating system interfaces — Python 2.7.8 documentation
Jeff
