List all coded and range values by domain group to table
3044
01-12-2023 07:49 PM
Jen_Zumbado-Hannibal
I'm not a programmer so forgive my ignorance ahead of time.
I want to extract a list of ALL the domains within SDE and group them by name with their corresponding coded or range values.
So far I've done it using Notebook and IDLE.
However, I don't know exactly how to arrange the results to look like a table. I read about DataFrames and arrays using panda but this is what I got so far:
import arcpy
import numpy as np
import pandas as pd
domains = arcpy.da.ListDomains("E:\ArcProMaps\MySDEConnection.sde")
for domain in domains:
    data1 = ('Domain name: {0}'.format(domain.name))
    s1 = pd.Series(data1)
    print(s1)
    if domain.domainType == 'CodedValue':
        coded_values = domain.codedValues
        for val, desc in coded_values.items():
            data2 = (data1, '{0} : {1}'.format(val, desc))
            s2 = pd.Series(data2)
            print(s2)
    elif domain.domainType == 'Range':
        print(data2,'Min: {0}'.format(domain.range[0]))
        print(data2,'Max: {0}'.format(domain.range[1]))
But I get this instead:
0    Domain name: piPipeShape
dtype: object
1         Circular : Circular
dtype: object
1       Horseshoe : Horseshoe
dtype: object
1             Oblong : Oblong
dtype: object
1    Rectangular : Rectangular
dtype: object
1    Trapezoidal : Trapezoidal
dtype: object
1     Triangular : Triangular
dtype: object
1               Other : Other
dtype: object
1           Unknown : Unknown
But what I want is something like this and/or easier to read and be able to export to Excel or perhaps a .csv file.
Domain NamepiPipeShape
1 (Enumerate them)Circular (Code)Circular (Description)
2Horseshoe (Code)Horseshoe (Description)
3Oblong (Code)Oblong (Description)
4Rectangular (Code)Rectangular (Description)
5Trapezoidal (Code)Trapezoidal (Description)
6Triangular (Code)Triangular (Description)
Domain NameSSM_YesNoUnknown
1Yes (Code)Yes  (Description)
2No (Code)No (Description)
3Unknown (Code)Unknown (Description)
etc, etc, etc.....
Also, not sure how to put range codes into a series/array/data frame.
I've read more community posts and documentation than I can count.
Please lend me a helping hand or at least guide me to the right direction.
Thank you.
Jen Zumbado-Hannibal, GISP
GIS Coordinator
City of Forest Grove
Forest Grove, OR 97116
2 Solutions
JohannesLindner
MVP Alum
# instead of a DataFrame, define your data as a simple twodimensional list
rows = []
column_names = ["DomainName", "DomainType", "Index", "Code", "Description", "Min", "Max"]
# fill the list
    if domain.domainType == "Range":
        row = [domain.name, domain.domainType, 0, None, None, domain.range[0], domain.range[1]]
        rows.append(row)
    else:
        for i, (k, v) in enumerate(domain.codedValues.items()):
            row = [domain.name, domain.domainType, i, k, v, None, None]
            rows.append(row)
# convert to DataFrame
dataframe = pd.DataFrame(rows, columns=column_names)
# export
dataframe.to_csv("N:/folder/domains.csv", index=False)
dataframe.to_excel("N:/folder/domains.xlsx", index=False)
Have a great day!
Johannes
Clubdebambos
MVP Regular Contributor
import arcpy
import csv
gdb = r"path\to\geodatabase.sde"
csv_filepath = r"path\to\export.csv"
domains = arcpy.da.ListDomains(gdb)
with open(csv_filepath, 'w', newline="") as csv_file:
    writer = csv.writer(csv_file)
    ## write the header
    writer.writerow(["DOMAIN_NAME", "DOMAIN_TYPE", "CODE/MIN", "DESCRIPTION/MAX"])
        print(domain.name)
                print('\t{0} : {1}'.format(val, desc))
                writer.writerow((domain.name,"Coded", val, desc))
        else:
            range_min = domain.range[0]
            range_max = domain.range[1]
            print("\t", range_min, range_max)
            writer.writerow((domain.name,"Range", range_min, range_max))
~ learn.finaldraftmapping.com
JohannesLindner
MVP Alum
rows = []
# fill the list
        rows.append(row)
    else:
            rows.append(row)
# export
Have a great day!
Johannes
Clubdebambos
import arcpy
import csv
    ## write the header
        print(domain.name)
        else:
Thank you @JohannesLindner and @Clubdebambos  for your help. It worked perfectly!
I just have to remember to import csv module too 😉
GIS Coordinator
