Layer's symbology polygon info stuck in "all other values" with arcpy
2253
5
04-26-2023 01:46 PM
danieloccasionally
I have some arcpy python code that successfully writes the symbology of a layer but the actual polygons only show up as "<all other values>". Any ideas on how to correct this?
The fields data are domain values, I'm not sure if that effects anything.
Here's the code:
import arcpy, sys, os
print(TWP)
aprx = arcpy.mp.ArcGISProject("Current")
m = aprx.listMaps("Map")[0]
l = m.listLayers(TWP + "_RIGHTS")[0]
sym = l.symbology
sym.updateRenderer('UniqueValueRenderer')
sym.renderer.fields = ['RightsType']
for grp in sym.renderer.groups:
    for itm in grp.items:
        label = itm.label
        if itm.label == "Choose":
            itm.symbol.color = {"RGB": [0, 0, 0, 50]}
            itm.symbol.outlineColor = {"RGB": [255, 255, 255, 100]}
            itm.symbol.outlineWidth = 0.75
            itm.label = str(label)
        elif itm.label == "Easement":
            itm.symbol.color = {"RGB": [0, 112, 255, 50]}
        elif itm.label == "Fee":
            itm.symbol.color = {"RGB": [56, 168, 0, 50]}
        elif itm.label == "License":
            itm.symbol.color = {"RGB": [255, 0, 0, 50]}
        print(label)
    l.symbology = sym
aprx.save()
print("Completed"+" "+time.strftime("%x" +" "+ "(%a)" +" "+ "at"+" "+"%I:%M"))
Tags (3)
danieloccasionally
I found that arcpy.da.UpdateCursor causes the polygons' information to be stuck in <all other values> and thus unable to display the symbology. @Anonymous User identified that this is bug.
by Anonymous User
Not applicable
If the itm.label is already a string label, setting it again is somewhat redundant and could be causing the problem with groupings there.  What does this give you, with omitting the assignment?
print(TWP)
sym = l.symbology
grpColors = { 'Choose' : {"RGB": [0, 0, 0, 50]},
              'Easement' : {"RGB": [0, 112, 255, 50]},
              'Fee' : {"RGB": [56, 168, 0, 50]},
              'License': {"RGB": [255, 0, 0, 50]}
        itm.symbol.color = grpColors.get(itm.label, {"RGB": [255, 255, 255, 50]})
        print(itm.label)
    l.symbology = sym
aprx.save()
print("Completed" + " " + time.strftime("%x" + " " + "(%a)" + " " + "at" + " " + "%I:%M"))
danieloccasionally
@Anonymous UserThat's some really elegant code.
Unfortunately, all of the info remains as "<all other values>"! I'm beginning to suspect that the issue is more basic. Since TWP + "_RIGHTS" is a File Geodatabase Feature Class, it's simply is not possible to apply symbology unless I convert it to a SHP file first which of course loses the domain drop-down fields.
by Anonymous User
Not applicable
That is odd, since it worked on a test dataset for but my value and label was both 0,1,2, though so it matched. It being in a fgdb shouldn't matter.  I wonder if it's grouping the value.  In your picture, the value is numbers, but the label is a string... what if you use the itm.values[0][0] instead?
grpColors = {'0': {'color': {"RGB": [0, 0, 0, 50]}, 'label': 'Choose'},
             '1': {'color': {"RGB": [0, 112, 255, 50]}, 'label': 'Easement'},
             '2': {'color': {"RGB": [56, 168, 0, 50]}, 'label': 'Fee'},
             '3': {'color': {"RGB": [255, 0, 0, 50]}, 'label': 'License'},
        d = grpColors.get(itm.values[0][0], {'color': {"RGB": [255, 255, 255, 50]}, 'label': 'Not Matched'})
        itm.symbol.color = d['color']
        itm.label = d['label']
        print(itm.label)
l.symbology = sym
danieloccasionally
It still didn't work @Anonymous User! Did your test layer have domains?
danieloccasionally
