Layer.getExent() Crashes Arcmap
3343
10
07-04-2012 11:56 AM
MikeHunter
The following code will crash a Python interpreter, or crash the entire Arcmap app if run inside the python window or in a toolbox tool:
import os, sys, time import arcpy  def main():          #make a layer from scratch     tfc = 'c:/arcview/sf/forest/tract.shp'     strmap = '4301'     t = 'tracts'     df = arcpy.AddFieldDelimiters(tfc, 'MAP')     exp = df + " = '" + strmap + "'"     result = arcpy.MakeFeatureLayer_management(tfc, t, exp)     lyr = result.getOutput(0)          # or get a layer from a .lyr file with the same def query     lyrfile = 'c:/temp/tract.lyr'      lyr2 = arcpy.mapping.Layer(lyrfile)           #either of the next 2 lines bombs python, or crashes Arcmap if inside app     ext = lyr.getExtent()     ext2 = lyr2.getExtent()  if __name__ == '__main__':     main()
The problem is the definition query, since both layers work fine without it.  The query works, and GetCount returns 1 for each layer.  This is 10.1, XP SP3.  Any help would be appreciated.
thanks
Mike
JeffBarrette
This was fixed and will be made available with 10.1 SP1.
Jeff
JeffBarrette
I can reproduce, I'll look into this.
Jeff
MikeHunter
Thank you sir.  Let us know if you figure something out.
Mike
JeffBarrette
This is a bug (NIM082523) and will be addressed for 10.1 SP1.  Arcpy is fetching a wrong (null) display transformation from layers generated from GP tools.
A possible work around it to reference the layers from within a Map Document.
1) Covert LYR to lyrfile, add to ArcMap TOC and reference it.
2) Use arcpy.mapping.ListLayers on the layer if it is automatically added to the TOC.
Thanks for reporting this,
Jeff
JeffreySchmidt
I have had a similar issue using .getSelectedExtent() in Python 2.7.  It restarts the shell whenever I use this method.  Glad to see it is going to be fixed.  Hopefully soon!
JeffBarrette
Jeff
Peter_von_Minden
Jeff
I have SP1 for 10.1 and I still get errors when using the layers getExtent() method on a layer with a definition query. The script hangs and dies unless I bypass all layers with a definition query in them.
JeffBarrette
I just tested this bug again using the original bug data and can NOT reproduce the problem using 10.1 SP1.
Its possible you have a different situation.  Please provide more details including part of your script.
Jeff
Peter_von_Minden
It's possible you have a different situation. Please provide more details including part of your script.
Jeff
Hi Jeff,
This is the code I was testing on:
import arcpy
mxdFullPath = r"C:\temp\test_with_def.mxd"
mxd = arcpy.mapping.MapDocument(mxdFullPath)
for lyr in arcpy.mapping.ListLayers(mxd):
    if lyr.isFeatureLayer == True:
        print lyr.name
        LAYEREXTENT = lyr.getExtent()
        print str(LAYEREXTENT)
In my mxd (test_with_def.mxd) I have a series of definition queries. The above code seems to work for some of these layers with definition queries (eg: RDCLASS = 'National Highway' on a roads layer) but it falls over when it reaches a contours layer with this definition query:
mod(ELEVATION,100)=0
The error in PyScripter, when I reach the layer with this definition, is:
EOFError: [Errno 10054] An existing connection was forcibly closed by the remote host
All the layers are Oracle SDE layers.
Your thoughts on the matter would be most appreciated.
Cheers
Pete
TomRutherford
I also have 10.1 with SP1, and am getting a python crash on layer.getExtent()
Here's a simplified version of my code:
Layers = arcpy.mapping.ListLayers(arcpy.mapping.MapDocument(A_mxd_path))
for layer in Layers:
        print 'layer:', layer
        extent = layer.getExtent() #crash here after printing some layers
Here's the output I get up to the time python crashes:
layer strippedrx_poly_check
layer shapefile
layer strippedrx_poly_vr
layer Yield1
layer Yield2
layer Yield3
layer Yield4
layer Yield5
layer Borders
layer VIEWS_2
layer VIEWS_2\Image mosaic
