Layer generated from python toolbox will not toggle on/off
1014
09-17-2025 01:50 PM
BrandonPrice1
Hello,
I am working on a python toolbox. I posted a couple weeks earlier about how to create a buffer layer based on the selected feature which I received help on.
The next step was for the toolbox to create an in memory layer from selected parcels that intersect the buffer. It seems to work, although the layer doesn't turn on/off when checked/unchecked. Also, the buffer layer shows up underneath it and nothing happens even when moved on top of it in the table of contents. Is there anything that can be done to fix these issues?
import arcpy
class Toolbox:
    def __init__(self):
        self.label = "Custom Buffer Tools"
        self.alias = "CustomBuffer"
        self.tools = [BufferSelectedFeatures]
class BufferSelectedFeatures(object):
    def __init__(self):
        self.label = "Buffer Selected Features"
        self.description = "Creates a 500-foot buffer around selected features."
        self.canRunInBackground = False
    def getParameterInfo(self):
        in_features = arcpy.Parameter(
            name="in_features",
            displayName="Input Feature Layer",
            datatype="GPFeatureLayer",
            parameterType="Required",
            direction="Input")
        out_buffer_name = arcpy.Parameter(
            name="out_buffer_name",
            displayName="Output Buffer Layer Name",
            datatype="GPString",
            direction="Input")
        out_buffer_name.value = "Selected_Feature_Buffer" # Default name
        out_intersect_name = arcpy.Parameter(
            name="out_intersect_name",
            displayName="Output Intersect Layer Name",
            direction="Input")
        out_intersect_name.value = "Intersected_Features" # Default name
        return [in_features, out_buffer_name, out_intersect_name]
    def execute(self, parameters: list[arcpy.Parameter], messages):
        params = {p.name: p for p in parameters}
        in_features = params['in_features'].value
        out_intersect_name = params['out_intersect_name'].value
        out_buffer_name = params['out_buffer_name'].value
        buffer_layer_file = r"C:\Documents\ArcGIS\Projects\Existing Land Use Generator\Existing_LU_Buffers (500ft).lyrx"
        aprx = arcpy.mp.ArcGISProject("CURRENT")
        m = aprx.listMaps("Map")[0] # Assuming "Map" is the name of your map
        parcel_layer = m.listLayers("ASSR_PARCELS")[0] # Replace "MyInputLayerName" with your layer's name
        with arcpy.EnvManager(workspace='memory'):
            # Create the full path for the output buffer feature class
            out_intersect_fc = arcpy.ValidateTableName(out_intersect_name)
            out_buffer_fc = arcpy.ValidateTableName(out_buffer_name)
            # Buffer the selected features
            arcpy.analysis.Buffer(in_features, out_buffer_fc, "500 Feet")
            # Make a feature layer from the buffered output and style it using layer file
            new_layer = arcpy.management.MakeFeatureLayer(out_buffer_fc, out_buffer_name)[0]
            final_layer = arcpy.management.ApplySymbologyFromLayer(new_layer, buffer_layer_file)[0]
            arcpy.AddMessage(f"Buffer created: {out_buffer_fc}")
            arcpy.SelectLayerByLocation_management(parcel_layer, "INTERSECT", new_layer, "", "NEW_SELECTION", "")
            arcpy.CopyFeatures_management(parcel_layer, out_intersect_fc)
            parcel_intersect = arcpy.management.MakeFeatureLayer(out_intersect_fc, out_intersect_name)[0]
            arcpy.SelectLayerByAttribute_management(parcel_layer, "CLEAR_SELECTION")
        # Add the layer to the active map
        aprx.activeMap.addLayer(final_layer)
        aprx.activeMap.addLayer(parcel_intersect)
        arcpy.AddMessage(f"Buffer layer '{out_buffer_name}' added to the map.")
BrandonPrice1
Please disregard the above post. I couldn't delete it. Everything seems ok now, maybe there was just a lag.
BrandonPrice1
