Layer exsitis help
1550
10-28-2013 10:57 AM
TonyAlmeida
MVP Regular Contributor
I have a python script that i would like to turn on some layers "if they exsist", if they don't exsist i would like for the script to continue to run. The current script won't run it give me an error
  File "<string>", line 8, in <module>
IndexError: list index out of range
This script will be used on about 5 mxd for a single project.
Note: some mxd don't have the layer "URNBAN_12" OR "RURAL_12"
The mxd with these layers added to the TOB run just fine with this script, but some mxd don't have these layers on the mxd and therefore it stops at line 8..
So how can i make the script continue to run past line 8?
import arcpy import os  arcpy.env.overwriteOutput = True  mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "URBAN_12")[0]  UR = "URBAN_12" if arcpy.Exists(UR):     lyr.visible = True  lyr = arcpy.mapping.ListLayers(mxd, "Rural_12")[0]  RU = "Rural_12" if arcpy.Exists(RU):     lyr.visible = True      mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "SUBJECT_PROPERTY")[0]  arcpy.env.workspace = os.path.dirname(mxd.filePath) wp = os.path.dirname(mxd.filePath)  del mxd  mxd = arcpy.mapping.MapDocument("CURRENT") lyr = arcpy.mapping.ListLayers(mxd, "SUBJECT_PROPERTY")[0] lyrpath = lyr.workspacePath  arcpy.env.qualifiedFieldNames = False  SP = "SUBJECT_PROPERTY"   lyr.replaceDataSource(wp, "SHAPEFILE_WORKSPACE", SP, True )  df.extent = lyr.getSelectedExtent() df.scale = 2000 arcpy.RefreshActiveView() arcpy.RefreshTOC()  del df  mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "1_2")[0]  S12 = "1_2"  lyr.replaceDataSource(wp, "SHAPEFILE_WORKSPACE", S12, True )  if arcpy.Exists(S12):     df.extent = lyr.getSelectedExtent()  df.extent = lyr.getSelectedExtent()     arcpy.RefreshActiveView() arcpy.RefreshTOC()
I appreciate any help.
Thanks.
JakeSkinner
Esri Esteemed Contributor
Hi Tony,
You can add a try/except to your code.  Example:
import arcpy import os  arcpy.env.overwriteOutput = True  mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] try:     lyr = arcpy.mapping.ListLayers(mxd, "URBAN_12")[0] except IndexError:     pass
JakeSkinner
Hi Tony,
TonyAlmeida
Excellent thank you.
TonyAlmeida
The current script works great for mxd that have layers in the TOC; Subject_Property, URBAN_12 and RURAL_12 and 1_2.
Mxd's that do not have 1_2 in the TOC give the following error
Runtime error
  File "<string>", line 29, in <module>
NameError: name 'lyr' is not defined
If i don't add line 19 "del mxd, df, lyr". The Subject_property will be updated by 1_2 feature class.
 import arcpy
import os
del mxd, df, lyr
try:
except IndexError:
    pass
S12 = "1_2"
del mxd, df
try:
except IndexError:
    pass
UR = "URBAN_12"
    lyr.visible = True
try:
except IndexError:
    pass
RU = "Rural_12"
    lyr.visible = True
df.scale = 2000
arcpy.RefreshTOC()
