Las to raster conversion problem
2419
10-07-2015 02:01 AM
MichalKowalski
Hello,
I have got problem with .las las to raster conversion. I use arcpy funcion LasDatasetToRaster_conversion and this function interpolates wrong. It makes wite areas around points. I use "binning average natural neighbor" with RGB to make ortophoto of the area. But other binning gives me the holes. Normally with .shp I use Topo to raster conversion and than I convert bands into standard picture with no holes. But I have to work with very big data and I use .las format. Please, do you know what I have to do to let computer fill the holes in the raster?
Thank you 🙂
https://www.email.cz/download/i/jkrvRdo812MZHZZODkIy63WduGcTwNyWqzB_CH2KwhKAG69hbD9T_Ua1iL9SQZRLb82g1yk/%C5%A0v%C3%A9dsko.png
DanPatterson_Retired
when you compare your code sample to that in the help topic LAS Dataset To Raster—Help | ArcGIS for Desktop
have you specified sufficient and appropriate options to obtain the desired result?  It would be useful to see what was specified and/or omitted in your case, as a starting point to solving the problem
