LaharZ issues
956
03-07-2024 05:01 AM
JoshConquest
I'm trying to model glacial outburst floods for my dissertation and have been looking into LaharZ. I'm not well versed in using python or even custom toolboxes so im having a lot of trouble with it. I believe I have installed the toolbox correctly however I try to create surface hydrology rasters and am met with the error message:
line 93
print arcpy.GetMessages(2)
SyntaxError: invalid syntax
I was hoping someone might be able to give some guidance on this issue.
thanks, Josh
DanPatterson
MVP Esteemed Contributor
if you are using ArcGIS Pro, it uses python 3.9.*, hence
print(arcpy.GetMessages(2))
`print` changed between python 2 and 3
... sort of retired...
