Join multiple tables to multiple feature classes arcpy
7640
12
03-31-2020 10:39 AM
NataliaGutierrez1
I need help to create a script that would allow me to loop through multiple tables in a geodatabase and join them to the correct feature class in another geodatabase. There are in total 77 tables and 77 feature classes. I would tell GIS to join those where a portion of the table name matches a portion of the Feature class name.
For example:
      Table Name 1: "NAL11F201901"
      Feature class 1: "T11"
       Table Name 2: "NAL12F201901
       Feature Class 2: "T12"
Important:
  • All of the tables and the feature classes have the same unique field name.
  • I need to join all of the fields.
  • The join needs to be permanent.
I am not sure if Add join is better to use or if I should use Join field.
I don't really know what to do next.
I would really appreciate any help with this.
Thanks!
import arcpy
in_features = r"D:\APRX_MXDS\USA_Parcels_2019_Project\Florida_Parcels_Per_County_Final.gdb"
join_tables = r"D:\APRX_MXDS\USA_Parcels_2019_Project\Florida_Property_Data_Per_County.gdb"
list_infeatures = arcpy.ListFeatureClasses()
list_join_tables = arcpy.ListTables(*NAL)
UniqueField = "CO_PARCELID"
for fc in list_infeatures:
    arcpy.AddJoin_management()
NataliaGutierrez1
Joe, the code worked!!  I am so happy! thank you so much! I was really stuck and needed to do this automatically. I used to do all of this manually for such a long time and I am learning to automate this with your help and with as many videos I can find online.
Actually, do you know of a good course that would teach me python applied to arcgis ? All I find are separate videos each one teaching different things. I would love to find something that goes from the very beginning until more advanced processes.
Anyways.. thank you again!
JoeBorgione
I'm glad it worked.  There is an instructor lead esri course; I took it it some time back. It was okay.  I've mostly just picked it up on my own with a lot of help from this forum.  Using ArcGIS Pro you can run a tool, get the syntax figured out and then create a stand alone script based on that.
There are lots of on-line python tutorials.  I like the w3schools stuff as they spell things out pretty succinctly. Python documentation is all over the web, so if just preface a question with 'python' you can usually find what you are looking for like 'python return last 7 letters in a string' or 'python for loop' or 'python if else'.....
NataliaGutierrez1
Thank you again! Will keep on learning and using the online tools
