Iterate Through MXDs to Change One Layer Data Source for Multiple MXDs
4966
13
03-18-2021 03:33 PM
rnaneliu
Hi,  I am trying to change the data source of our parcel fabric that is not being maintained to a new one stored in the same SDE dataset.  I have created a script to the best of my ability and I get this error.  I have searched for possible solutions all day.  I am sure it's a simple solution but this is time sensitive and I need to figure out what I am doing wrong as soon as possible.  Thanks for any help you can offer.
ERROR:
if lyr.name == "Fernie Parcel":
NameError: name 'lyr' is not defined
import arcpy
from arcpy import env
from arcpy import mapping
arcpy.env.workspace = workspace = r"P:\mxd_data_source"
mxdList = arcpy.ListFiles("*.mxd")
for mxd in mxdList:
mxd = workspace + "\\" + mxd
print mxd + " is being processed"
mxd = arcpy.mapping.MapDocument(mxd)
for df in arcpy.mapping.ListDataFrames(mxd, "*"):
lyr.replaceDataSource(workspace, "SDE_WORKSPACE", "parcel_pmbc", validate=True)
print "Successfully updated data sources"
mxd.save()
by Anonymous User
Not applicable
Yes, that was my fault for using workspace like that.  By checking the workspace I was meaning the datasource string such as 'CF on SQL-DEFAULT.sde\CF.SDE.Base' but that might not be necessary.
What are the two layer names?
rnaneliu
Hi Jeff,
No worries, appreciate the help.  The layer names are CF.SDE.parcel and CF.SDE.parcel pmbc. Cheers,
by Anonymous User
Not applicable
ok- it wasn't getting that second layer because I don't think we were telling it to.  From the docs for the data_set parameter:
A string that represents the name of the dataset the way it appears in the new workspace (not the name of the layer in the TOC). If dataset_name is not provided, the replaceDataSource method will attempt to replace the dataset by finding a table with a the same name as the layer's current dataset property.
So we could try:
pathToSDEConnection = r'Path to your connection file'
# arcpy.env.overwriteOutput = True
for mxd in mxdList:
    mxdpath = workspace + "\\" + mxd
    mxdMd = arcpy.mapping.MapDocument(mxdpath)
    for df in arcpy.mapping.ListDataFrames(mxdMd, "*"):
        for lyr in arcpy.mapping.ListLayers(df):
            print lyr.name
                arcpy.AddMessage("Updating connections: {}".format(lyr.name))
                lyr.replaceDataSource(pathToSDEConnection, "SDE_WORKSPACE", "parcel_pmbc", validate=True)
                lyr.replaceDataSource(pathToSDEConnection, "SDE_WORKSPACE", "parcel", validate=True)
    mxdMd.save()
    print("Done updating data sources in {}".format(mxd))
rnaneliu
Thanks Jeff.  I ran the script. It went through all of the mxds but didn't change the source.  My email is [email protected]. I would love to fix this problem but it just could be on our side.
Cheers,
